Starting in Sport Plus w/ Perf Exhaust (flaps open)
Old Feb 28, 2019 | 04:17 AM
Pioneer222's Avatar
W213 AMG 2019 E63S Wagon
I am not advocating doing this in the morning to annoy neighbors... And I only mention this because some people say the first thing they do is open the flaps after starting (if they have performance exhaust)
But interestingly. When I took delivery of the 19 E63S Wagon at the Center of Excellence here in Germany, and the rep was showing me how to start up, engage options etc. I asked why, if you had the flaps open when you turn the car off, does it go to quiet mode upon start up next time (only being in comfort mode as the only option). He said it is not possible to crank the car with the flaps open, probably to be quiet in the AM, and also to possibly comply with German law, because with flaps open it might not pass the noise inspection...
However, it is possible to crank with flaps open... Without touching the brake, if you turn on the ignition (hit the start button once, then again, then select sport plus, then put foot on the brake, and start - it is a whole different sound starting up - especially if the car is already warmed up. You even get the gargle and pops. I mainly mention this because sometimes people just want to see/ hear your car and starting it this way occasionally is a different experience. Sorry if everyone already stumbled on to this - This is my first MB!
Old Feb 28, 2019 | 06:40 AM
Dunga's Avatar
'23 SL63 AMG, '24 Range Rover SE P400, ‘26 Corvette Z06, ‘25 Audi RS7 Performance
During my delivery yesterday they showed a similar trick, only instead of popping it in sport plus, he put in auxiliary mode, then pushed the exhaust button. Et voila.
Old Feb 28, 2019 | 06:48 AM
Pioneer222's Avatar
Right, that works as well. Doing that is similar, allows opening the flaps but then cranking in comfort mode. I think the initial rev that must be higher in sport plus gives such an explosive sound - depending on when one might want this. Because of the higher rev I think doing this when the car is already warm is safer. Thanks!
Old Feb 28, 2019 | 07:45 AM
Ralcbah's Avatar
2018 E63S
When my car was stock I used to do this! Sounds pretty aggressive...also did it quite a bit after I went catless. Now that I have a full turbo back exhaust, I don't do it anymore. Way too loud and obnoxious. Even coded out some of the cold start. Never have I thought a car was too loud upon start, but with full exhaust, this car achieves it...
