Coolest temp and fans running.
Old Mar 1, 2019 | 10:22 PM
cyclrder's Avatar
18 E63s Wagon 15 GL63 (sold), 10 Turbo TT MT, A36 Bonanza, 20 JLU Rubicon
k
Last edited by cyclrder; Mar 2, 2019 at 08:24 AM. Reason: irrelevant... referenced wrong data in dash
Old Mar 1, 2019 | 11:26 PM
wassup61's Avatar
E63S4S
You have a punctured radiator... seriously.
Old Mar 2, 2019 | 05:12 AM
guhvies's Avatar
2017 C43 AMG Saloon
In addition, check the radiator coolant level. I seriously hope you don't have to replace the replaced radiator.
Plus get the radiator/side pod guards and put them on. See this.
Old Mar 2, 2019 | 11:34 AM
Michael Khan's Avatar
Originally Posted by cyclrder
k
what were your readings?
Old Mar 3, 2019 | 07:59 PM
cyclrder's Avatar
I discovered that you actually can’t get a temp reading for coolant. The temps in the AMG gauges are for gear and engine oil.
but since my repair the fans will run after I have driven the car for a while and they are super loud.
Old Mar 3, 2019 | 09:25 PM
whoover's Avatar
'19 E63S sedan
Under the Service menu, there's a Coolant submenu. It shows temperature from C to H, without numbers oddly.
Old Mar 4, 2019 | 09:55 AM
cyclrder's Avatar
oh! That is very useful information. Thank you, I will update after looking st that gauge.
Old Mar 4, 2019 | 10:55 AM
bobblehead's Avatar
go fast grocery getter wagon
Mine is at the middle of the graphic bar ... which is around 90 degree Cel.
Old Mar 4, 2019 | 12:34 PM
cyclrder's Avatar
Do you ever hear the fans come on?
Old Mar 4, 2019 | 01:06 PM
whoover's Avatar
'19 E63S sedan
When I pull into the garage, the fan is always on.
Old Mar 4, 2019 | 01:16 PM
Does the car have a icon or a warning message if the radiator is damaged. I usually drive a bit aggressive on the way home and when I park the car the fan is like running pretty loud.
Old Mar 4, 2019 | 03:05 PM
wassup61's Avatar
E63S4S
No, this will not trigger a warning light.
The coolant temp gauge(s) for the high temperature (engine) circuit are "dummy" and dont report values the same way as the oil and transmission temperature sensors. Normal operating temperatures are "in the middle"
Generally speaking, high speed secondary fan is normal after running at high loads.
Where there should be concern is when it is consistent, and when you see the secondary (low temperature trans/charge air) cooling circuit going into the 100*C range quickly and consistently with high fan speeds. You can do a visual inspection of the coolant bottle under the engine cover as well, this level should never fluctuate below minimum unless there is a leak (punctured secondary radiator).
Old Mar 4, 2019 | 03:06 PM
cyclrder's Avatar
nope.. no errors.
... it just sounds really really loud. and no leaks.
I am thinking that when they changed the radiator out that something has gone wrong with one of the sensors causing all of the fans to come on. I hadn't been driving the car hard on these occasions and it had had a fair amount of time to "settle" down.
Wassup61. thanks for a thorough description of how the fans work.… it is refreshing to have knowledgeable responses on the forum.
Old Mar 4, 2019 | 05:24 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
My commute is less than 5 miles. The fans are typically running after I park the car in the garage and I know the car isn't even fully warmed up.
I think they shut off fairly soon after I turn off the car, but I don't typically wait around for it to happen.
Old Mar 6, 2019 | 02:29 PM
CALBenzo's Avatar
'18 E63S AMG
Is it just the fans blowing after we park? I assume that oil is flowing over the turbo bearings for cooling, although I haven't really looked into it??
