2018 63s 1 year review
It is more comfortable than my previous cheaper cars. On City drive and B roads it's good enough. Yes it could be more comfortable given that, for instance, BMW and Porsche do it, but it is good enough in comfort mode.
The only grievance I have is the tire road noise. Even with acoustic package the noise is high for a mile eater that this car is. But then again, I am driving it at 160/180 kmh average...
But the engine sound, response, looks and driving pleasure are over the top and overcome the negative aspects
Mercedes chose Airmatic for AWD AMG's; this wasn't that welcome of a move as Airmatic didn't have a great reputation for reliability nor for being performance oriented. ABC is much better suspension and more capable
Second, tire pressures from the VPC come 15-20psi over what they need to be. Tires at delivery are pumped up for MAX load, which leads to a comically rough and loud ride. Air them down to levels on the tire sticker under the gas cap for a much more compliant ride.
Third, if you have the sports buckets you have 1/3-1/2 as much padding, therefore any rough aspects of the ride are amplified due to the relative lack of insulation between you and the road.
I'm currently on Potenza RE980AS All-Seasons for the winter inflated to the correct pressure for normal driving and it's like riding on a cloud in comfort mode, not far from my wife's '18 Fullsize Range. In temps above 40, the Pilots that came on it are close at the right pressures. At the MAX LOAD pressure they came with it felt like driving on pebbles all the time. And I skipped the sport seats, so the 9400 miles I've put on the car have been smooth and comfortable...unless I pop it into S+ or Race, where it turns into a car that beats my old SLS in almost every area besides cool doors.
The E has Airmatic...
on the track day, in the pit stops, my car was serviced by a Pirelli team and they recommended keeping them higher but less than what the VPC and brand states. for running on the track they placed them at 2.8/2.2 bar (41/32 psi) and thank God they done that because i got the front tires to 75ºC...
for what i read they changed something in the springs and shocks on the Air Body Control suspension, so it is more close to ABC than Airmatic
-Seats: I have the performance seats, got them for the looks. No complaints.
-Ride: unnecessarily harsh. Does not need to be this harsh on Comfort mode.
-Doors: Doors do not stay open with any sort of incline despite 2 changes on the hinges. Poor engineering for the cost of this car.
-Engine: awesome, had it chipped right after purchasing it so I cannot really compare with stock performance. Really do hate the "lag" on normal driving. When you have to floor it, the car lags like molasses. Just to be fair I am comparing it to electric cars (which is the future).
-Tires/Transmission: the car skips when cold. Not sure if this is the tires or the transmission not keeping up. Never had this in previous cars. Kind of like applying moderate acceleration on rear wheel cars and having the wheels spin slightly. With this car I am not really acclerating hard when this happens.
-Electronics- ok. These dinosaur companies will eventually be forced to go to the Tesla/Apple model. God knows why they can't update the software even at the dealership (god forgive over the air updates). I would love to have the Track pace app and other new changes. My wife's Tesla has new features automatically updated every few months with no charge or fees.
-External: Front end- awesome. Side- ok. Rear- ugly
Overall for my purposes I really love this car as a package. I think I've only seen one in the wild since owning this car, so kind of nice to be unique. My two cents worth.
ABC is hydraulic and is fully active. Damping at each corner is constantly varied to deal with static factors (number of passengers, height settings, driver selection of handling characteristics, etc.) as well as dynamics (road surface and imperfections). You can think of it like noise-canceling headphones. As a wheel starts to respond to a dump or dip, servos apply an opposing force. Older ABC responds to bumps as they happen, while Magic Body Control responds to upcoming bumps by scanning the road ahead. It's a very complicated system, is very expensive to maintain but works amazingly well at making cars like the S65 exceedingly comfortable but reasonably well handling. The lack of body roll in an S65 is hard to believe for a car so big and heavy and the effect on ride comfort over real-world roads is obvious.
Other than complexity, the big negative for ABC/MBC is inability to support AWD. It was developed before AWD became so important and never upgraded. That's why most performance-tuned S-classes and our cars use the pneumatic Airmatic systems. Airmatic is only semi-active. It changes damping in stages, not continuously, and only for fairly static factors. That's why we can control firmness and change the car's level (or have the car do it automatically for certain reasons). It also manages body roll by using fairly simple and static means, like responding to yaw sensors. But it doesn't allow the continuously variable damping with millisecond latency needed to make roads seem unflawed.
An AWD fully active suspension would be an amazing advancement.
So I either go to S+ in advance or manually shift down.
Tires are Michelin Pilot 4S which I suspect will need to swapped out in winter. 42/41 front to rear. Tire noise yes but comfortable in comfort. I got standard seats as wife complained about the performance seats.
build quality vs C63S is day and night. No squeaks and rattling in this car.
One regret is is no HUD. Otherwise awesome all rounder car.
13 months in and I love my E63S sedan. Ride being a little too harsh is the biggest issue but to be expected. I don’t feel the ride is too harsh but the roads in Philly too poorly maintained.
Your tire comment would only make sense with Pirellis. The Michelin PS4s are fantastic and have great grip.
I personally love the performance seats but it was quite a switch from our S-Class super comfy dynamic bolster massage seats. They fit tight and are comfortable.
The issue is likely the suspension which I consider the only real weak point of the car. This is Airmatic pumped up to max pressure for sporty handling, making the car less compliant and unnecessarily stiff. There really is no comfort mode and the ABC suspension would have been better choice. Or at least a better calibration. This is the stiffest AMG I know of.
In regards to the engine, the 4 cylinder mode is not really meant for city traffic. When you cruise in comfort (typically highway) that mode dynamically engages if a fuel savings benefit is seen. Like the sailing mode. Worthless and needed as much as ECO mode in an AMG - just a nuisance ...
When it comes to electronics there are two 2018 models; the early and the late 18 builds. The early 18's are really 2017 model when it comes to the hardware version of the electronics and there are several modules that impact speed of the interface, Comand interface features, CarPlay, Interior LED's etc.. That improved on late 18 builds and got better on the 19's. Ours is the early build unfortunately and not upgradeable...
LF
However, there was at least one change that my car did not get that came along a month or so later. I only have one 12 VDC outlet in the car, the rear one. My car has CF center console and did get the wireless charging, which in the DOG at the time was not an option. The 12 VDC jack in the center console was moved to make that happen. In later cars it was relocated to somewhere near the left knee of the front passenger. It's nowhere to be found in my car.
