Warped brake rotors
I find the lane assist over bearing, it goes off when you are purposing going over a line to give the other vehicle room . Is their a way to adjust sensitivity?
All,
My 2018 E63s wagon is damaging steel rotors, I’m the second owner, first owner replaced first set at 7k miles, I replaced the second set at 11k miles and now, barely at 13k miles the rotors are once again vibrating which is more than likely the same issue - MB replaced everything under warranty
Car has been driven carefully, garaged and well cared for etc, never tracked, raced, abused in any way
The first diagnosis was that the wheels were over torqued, 110 lb-ft dealer adjusted back down to 95 I believe, same issue now - 2 owners
Stock wheels, rotors, pads, no mods
Does anyone have any ideas as to what could be causing this? I’ve owned over 30 sports cars over the years, I am very careful and have great “mechanical sympathy” never had this happen before, not even on track cars
Any guidance is greatly appreciated
thank you much -
thank you much -
