Help w lowering module
Old Jun 15, 2019 | 04:11 PM
Mike Youngs's Avatar
What’s the perfect lowering specs number for the 18 e63s using the lowering module, I can’t seem to sent my car on the perfect height without having the ride so harsh . Thanks
Old Jun 15, 2019 | 08:44 PM
apsuard's Avatar
Empty
I think low is 40/40 based on a previous post. The seller says it 32/32 on a video though. I do think the car looks better with rear lower than front to equal it out.
Im at 31/36 and really like the look. The low setting just looked to slammed for me.
Old Jun 18, 2019 | 11:24 AM
Mandarin's Avatar
e63s
I have -15mm all around and ride quality is the same.
Old Oct 2, 2019 | 10:52 AM
panameraTT's Avatar
2018 E63s Wagon
I wanted to add my two cents here. I have the same module for my 18 E63s Wagon, it is an awesome and relatively inexpensive mod ( I bought the one on Ebay). After messing around with the custom settings and using the round toggle, it is really fun and easy to change the look ( and Ride) of your E63. I started with the low setting, but it was too low for comfortable driving. Looks wicked cool though. I went to -22 both front and rear, and the look was also pretty stellar, but the ride was really rough, almost like sport +. I felt every nook and cranny on the road. My wife also commented that she felt everything. So I took it back up to -15mm both front and back. This is for me the best combination so far. The look of the car is better than stock, and the ride is the same as the stock OEM height. That small difference, 7mm, seemed to make a world of difference. The car is compliant and predictable.
Now if I was parked at a car show, I would lower it down for the look. The cool thing with these modules is you can change the look and drivability by yourself in all of 30 seconds. No need to go to a guy....no need to head to the shop....just plug it in, click thru to the custom menu, set and save. I will continue to experiment with smaller increments here and there. Kudos to the guy that figured this out. For $400 this is a must have.
Old Oct 4, 2019 | 09:13 AM
Dmitry Gebber's Avatar
Mercedes-Benz
Absolutely agreed. I use -20mm in front and rear on my s560.
Old Oct 4, 2019 | 09:36 AM
user 8392082's Avatar
2018 E63s
I was looking into lowering mods.. Can you mention which module on eBay you are using?
Old Oct 4, 2019 | 09:47 AM
dav461's Avatar
GTR
This one https://www.ebay.com/itm/MERCEDES-BE...IAAOSwV5law-kg
Old Oct 4, 2019 | 09:49 AM
2018 E63s
Thanks! I see he jacked the price another $100.. lol.
Originally Posted by dav461
Old Oct 4, 2019 | 10:29 AM
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
Yesterday I went to order one and saw it had gone up. Decided maybe 17mm wasn't such a big deal.
Old Oct 4, 2019 | 02:22 PM
dav461's Avatar
GTR
can try to make you a discount (50$ or more) when you will be ready to order.
Old Oct 11, 2019 | 06:00 AM
Fabio Montico's Avatar
S560
Amazon ca Amazon ca
Here you could buy it at the old price
Old Oct 15, 2019 | 12:04 AM
JODE63's Avatar
e63 Wagon | Porsche 993 Turbo | Ferrari F355 GTS, Defender 130
Just ordered mine! Maybe I'll have it in time for my European Delivery...
Old Oct 15, 2019 | 12:35 PM
Michael Khan's Avatar
Does this void the warranty ?
Old Oct 15, 2019 | 01:36 PM
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
do you need to get alignment redone if you lower car 20-30mm?
Old Oct 15, 2019 | 06:36 PM
Originally Posted by Andrea Teofilo
I bought one from Amazon and it works perfect.
The guys know their job well.
looks really good. how low did you go front/rear?
Old Oct 16, 2019 | 02:26 PM
doba_s's Avatar
M3
I got mine and it's -25mm ...
Old Oct 18, 2019 | 11:56 AM
So which module is the best one to get?
Old Oct 18, 2019 | 12:50 PM
dav461's Avatar
GTR
All same.
Old Oct 18, 2019 | 12:56 PM
Originally Posted by Andrea Tiofilo
Low mode
-32mm in front and rear from factory settings
did you need to redo alignment?
Old Oct 18, 2019 | 03:27 PM
SLcharge's Avatar
09 SL500, 03 E320 CDI Wagon
As usual, this is one of those things are very personal, and up to the eye of the beholder, how much a car should be lowered to look cool. I prefer that the tire is symmetric with the wheel arc, meaning that there is the same air gap between tire and wheel arc all way round.
Old Oct 21, 2019 | 09:16 AM
Irfan1712's Avatar
w213 E63s
Really happy with the module from eBay as others on here.
I first had it in 'Low' mode which I believe is -32mm all around. The ride was pretty harsh. I also noticed the rear was sat slightly lower than the front which was bugging me!
Its now sat in Custom mode in these pics, -32mm front, -28mm rear. It rides a lot better just from that +4mm on the rear from low mode. The rear tyres are profile 35 though, they should be 30 (my mistake when I ordered them!) so I think that's why the rear looks lower when in actual fact the tyre is thicker than what it should be.
Alignment booked for this week, Spacers pending (H&R 15mm front and 13mm for rear). Overall, love it.
Old Oct 22, 2019 | 10:33 AM
How does it lowering module work. Can you set the ride height on each mode or is it one height for all of them?
Old Oct 22, 2019 | 10:42 AM
dav461's Avatar
GTR
yes, its one for all, but it doesnt over ride settings, so if you set -30 all around on comfort mode, then push S+ suspension, car will go even lower.
Old Oct 22, 2019 | 11:25 AM
your rims look great. is it because your car is new? i would consider ceramic coating them to keep them so clean.
Old Oct 22, 2019 | 12:53 PM
dav461's Avatar
GTR
Hey Irfan,
Does your HR kit include extended hub bolts? if yes, can you share part number for spacer kit please.
