Eurocharched Or DME Tuning - opinions needed
Hello guys,
so i am thinking about installing down pipes and doing ECU upgrade to stage 2 but i cant decide which to go to eurocharched or DME ?
What do you think and if any tuners please write your opinion
You might want to consider AMR too. Great customer service and tuner!
DIVINE AMG (08-01-2019)
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
https://mbworld.org/forums/w213-amg/...npipe-kit.html
In terns of tuning it all boils down to who you can communicate with the best. We use EC for our tuning needs.
b6tbfmp (08-01-2019)
There's some information online pertaining to tuning W213s yourself for nearly free, if you are a risky kind of guy
Just get a USB -> CAN device for $30 from https://store.protofusion.org/product/canable/, then get a OBD-II female -> pigtail connector for $13 from
Connect the two (CAN high + CAN low), plug the device into your laptop + car, look online for a UDS flasher (hint hint hint, I know a guy who wrote one as free open source software), tune a map you can get for $99 from any WinOLS reseller online.
All you need is the seed/key algorithm for the UDS SecurityAccess request for the MED1775 ECU.
Bam, $99 tune by reputable company who tune tons and tons of German cars at high volume, not $2k tune.
https://www.amazon.com/iKKEGOL-Connector-Diagnostic-Extension-Pigtail/dp/B07DZXXG72/ref=sr_1_5?keywords=obd+pigtail&qid=1564689197&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&s=gateway&sr=8-5
Mandarin (08-02-2019)
I've worked with each of your options...all good results and good people. Kevin did my w212, w213, and will likely do my m5 at some point too...he's super talented and just a good dude.
How are you going to get your car on a lift and "weld" cut the stock downpipes?
Luckily I own a gas station with a few friends and it has its own shop, so I will take it and do it myself on the weekend when the shop is closed. I am pretty good with welding and stuff since I used to be a FFA Aircraft tech.
