E53 Oil Change Procedure
2019 E53 Coupe
Hello everyone,
I just purchased a 2019 E53 (six cylinder inline) and I am looking for an oil change procedure for the vehicle. Can anyone contribute?
Received 4,003 Likes
2017 GLE350 4MATIC
Welcome! Please post a photo of the E53.
Removal by suction is generally the method used these days, for oil changes. Mitivac is a well accepted brand of oil removal pumps. Dealers typically use a fitting on the end of the dipstick tube that allows rapid and complete removal of oil. I have not found this fitting online, and no one on this site has provided a source for it. Consumers typically use a plastic tube that is inserted into the dipstick tube, into the sump. This is a somewhat slower process than the dealer uses, and may not evacuate 100% of the oil volume.
Looking at photos of the M256 inline six cylinder engine, I don't see obvious dipstick handles. Commonly these are found on the left (driver's side in North America and continental Europe) side of the engine, toward the rear. If you remove the engine cover, the dipstick will likely be in plain site, with a colored (red, yellow or blue are common) handle or grip.
I suggest Mercedes replacement filters.
I hope someone on this site can give a definitive link for the fitting used by the Mercedes dealers, which attaches between the oil removal pump and the dipstick tube.
2019 E53 Coupe
Question for the forum:
1. Is the arrow pointing the the engine oil drain plug on my 2019 E53?
2. Does the oil drain under gravity w/o any vacuum assist apparatus?
3. Must any seals or drain plug be replaced?
What grade of oil did you use for the oil change. The manual says 0W-20 with MB Approval 229.71. I will be due for my A service soon and the dealer seemed unaware of the new oil specification for the E53. They are having trouble getting the oil. Has anyone been successful getting an E53 oil change with 0W-20 MB 229.71 oil?
F1le (12-04-2019)
Why I don't have it in my technical book (but for CLS 53AMG), it's only 229.71 ... Damn... Can you show a cover of this book?
Don't fully understand this one :
E53, E63S : only use 0W-40 or 5W-40 while it was told initially that 229.51/52/61/71 are norms (5W30 or 0W20). Looks like a mistake here?
Honestly i had to read it a couple times myself. Also somebody asked for a dipstick location of the m256 engine, it does not have one so oil change by pumping it out seems unlikely.
You have only "virtual" dipstick... I was trying to find it out too, but also thought the electronic one is quite nice, had BMW '15 with both, but this electronic one was working very bad. Sometimes you add a quarter and after 2 days of driving it caught the quarter.
BTW : Still asking you how to interpret this info that E53, E63, E63S (it's a mistake in this book, as there are 2x E63S) should require 0W40 or 5W40 (I personally think it is a mistake in E53). I was amazed with 2 MB services too.
One : 0W40 like all AMGs, Second : 5W30 best with 229.52
Still got 1000-1500km for first 2000km to make an oil replacement, but weird, but already bought 10L of 5W30 229.52... Replace air filter 75k km ... WHAT A JOKE!!!!
This is European book or US one?
this is a usa book. honestly i dont know how to explain it i went to the dealer here in chicago the information that they provided me was worse than useless regretting for prepaying service for 4 years. im due 1k miles for my oil change i dont do 10k miles as the book suggests but 5k miles change but this will be the first one. last resort will be to drain some oil and send it to an oil lab i think they can determine the viscosity.
i would send my own samples, of coarse i would not expect any dealer to do that.
I’m having the 229.71 0W-20 oil change in my E53 Coupe tomorrow morning. It took a couple of weeks for the dealer to figure this out and get the proper oil.
I don't want to drive on 0W20 ... NEVER EVER it's a water with very thin oil film. Such oil is good for 1.0L engine but not for a 3L 450HP engine god damn it!
2019 Mercedes AMG E53 2002 Mercedes C-Coupe Kompressor
I don't think you can go wrong with a current spec 0W40 syn.
Edited to add : why would you want to change your own oil anyway?
What to you all think is the biggest reason for oil change, mileage or time? I always seem to hit time (in this case one year) before mileage.
Understanding the MB 229.71 Specification
lubrizoladditives360.com/understanding-mb22971March 14, 2018
MB229.71 is based on ACEAEuropean Automobile Manufacturers Association (Association des Constructeurs Européens d'Automobiles). The primary automotive standards organization in the European Union, ACEA defines performance specifications for automotive lubricants.C5-16 which is the fastest-growing engine oil category in the European lubricants market today. The Mercedes-Benz vehicles requiring this class of lubricant are now approaching their first in-warranty service intervals and this will lead to a rapid increase in demand for these lubricants.
For more information on Lubrizol’s solutions for passenger car engine oils, contact your Lubrizol representative.
229.71 aproved oils
there is not a single 229.71 oil on the US market, not even dealer has it. im not saying its not the right one just simply stating there is nowhere to order or buy.
for anyone interested oil drain plug part number is : 002-990-20-17
229.71 aproved oils
As a car engineer who used to work 10Ys in car manufacturer central I’ve learned couple things :
- use the highest viscosity of oil available and of course approved to your car (car will burn a lot less higher viscosity oil than lower one, so might not burn 5W30 at all and take quite a lot 0W20)
- higher viscosity provides much much firm oil film and is desired the hotter temperatures you use your car.
- change oil after first 1500-3000km
- change oil much more frequent than it is provided in the manuals. Remember about transmition oils, gearbox oil etc. (Engine oil about 10-15k km interval as in EU this interval is around 20-30k km)
- always after running a car on no speed limit highways when you turn to gas station wait 2-3 min idle to cool turbo charger.
I’ll let you know what my MB Central tell me once I’ll get an answer.
JuliusLaSalle (12-05-2019)
229.71 aproved oils
@F1le
i am definitely waiting MB central to reply to you. I agree with you about 0w-20.
He was digging like 5min in his computer and admitted he was WRONG... All engines with particular exhaust filters (53 has got it) they use 229.52 5W30 and yes only 229.51/52/61/71 and allowed are 5W30 (229.51/52) and 0W20 (229.61/71 - which they due to the same reasons I don't want to have - they don't even propose their customers so they fill those cars with 5W30 229.52).
@F1le
Even 5W40 are allowed ... everything below is valid, mostly you have to obey norms 229.51/52/61/71 and some 229.51 are even 5W40. Mercedes does not care what viscosity you choose as long as you keep their norms... Spread from 5W40 to 0W20 - mostly 5W30 in 95% cases.
Saying short - if you find 0W40 or 5W40 with 229.51 you can go ahead. Viscosity is #2, just obey any 229.51/52 if you want to protect engine, or 61/71 if you want to be super-eco.
https://bevo.mercedes-benz.com/bevolistenmain.php?navigation_path=oilfinder&langu age_id=1&content_action=show&carspecid=7062
The following 3 users liked this post by F1le:
