Downpipe Smell
it’s not bad but would have probably opted for hi flow cats vs the catless...
From the oil level gauge my car seems to be doing well from that standpoint and holding firm, but since the car was new and continuing today I smell a bit of a hot oil smell if I have the windows down or when I get out of the car.
More from the engine area than the exhaust area.
BTW, no leaks on the garage floor a home or at work.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
