CCB brake pad warning light..14,000 mi.
Old Aug 22, 2019 | 10:30 AM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
Originally Posted by amgliturbo
Is the problem lessened if you drive in Sport+ or Race Mode? I would assume so. My Individual setting is set with comfort suspension (or Sport suspension activated by pushing the suspension button once) Sport+ for the tranny and ESP off. I am assuming ESP off will result in less wear on the CCB pads. I like the feel of the car with the ESP off--as I understand it the nannies are not completely disabled and the car is much easier to rotate in turns with the throttle. If I don't know the roads than I just use Sport+ as it is set by the factory so that the nannies are there to help if need be.
Yes, I found the brakes don't get as hot while in individual manual Sport+ mode going up hill but they still get to the point of giving off the hot brake smell when you pull over.
Old Aug 22, 2019 | 03:33 PM
6G Schnell's Avatar
2021 E63S and 2025 GT63
Talking
Please help me understand: spirited “driving in the canyons” heats up the brakes. And one would expect they smell like roses when pulling over?
Old Aug 22, 2019 | 04:06 PM
ronin amg's Avatar
The Mercedes ESP system works by applying braking pressure to the wheel it senses needs to slow down to maintain stability the corners..
Old Aug 22, 2019 | 05:22 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
That and limit wheelspin even if you're on a stable trajectory.
I'm typically in Race mode when canyon carving because in Sport+ the little ESP icon winks on regularly.
Around town I'll also pop it briefly into Race mode for certain corners where I know ESP activates in Sport+ mode.
I've only disabled ESP under controlled circumstances in large parking lots where I won't be a danger to traffic or myself. Same for drift mode.
Old Aug 22, 2019 | 07:49 PM
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
Originally Posted by Dunga
They are heavy. Hopefully you’re just looking at pads for CCB. Just did my rear pads and rotors on the wife's GLE 63s at 15,000 miles. Pads and rotors were around $1,500 with labor but CCB are a lot more for rotors. Let us know.
edit: I was told my pads were at 4 mm before the metal, and the rotors were warped. No track or even canyon carving even. It’s just the family SUV that hauls baby and dogs. It is 5,200 lbs though with 577 hp rear biased so like ronin said ESP doesn’t want you to die and cooks the rear brakes.
all 4 pads alone are $1,100 with labor non-CCB
with rotors is wayyy more expensive, CCB or no -CCB
Old Aug 23, 2019 | 12:19 PM
ronin amg's Avatar
I like the fact that it works better in Sport+ mode and I won't turn it off completely since it helps to control the beast...
Now to flush the fluid again with Castrol SRF
