Is Sport+ faster than Sport and Comfort modes?
Does the car unleash all of its power (albeit without a stiffened suspension, or growling and popping exhausts) because it can tell you want full power from your hard press of the throttle? The most noticible difference in Sport+ appears to be the car likes to stay in the gears longer, which the RPMs shooting up to the 5K range before shifting to the next higher gear.
Said another way, does driver input override what mode you are in, or is the MB drive mode selector similar to Tesla's ludicrous mode where you car's potential isn't activated until you select the higher driving mode on the selector switch?
Ludicrous mode in a Tesla works by increasing the amount of electric power delivered to the electric motors driving the wheels of the vehicle. With more power delivered to the wheels, that equates to more hp and a faster discharge of the battery. So you can't compare what the MB modes do in comparison to what ludicrous mode does in a Tesla. Apples and oranges.
There was some talk on here that the e63s is basically holding itself back at all times, in all modes, in order to deliver nearly identical performance (in terms of acceleration), regardless of atmospheric conditions, gross vehicle weight, paint color
, etc. The car takes it easy when conditions are perfect, and you get X as a performance result. The car puts in a bit more effort when conditions are imperfect and you still end up with X. I believe this theory was substantiated by a few draggy pulls...but I am a sucker for a good story so I am all in on this theory.
There also seems to be a theme with the tuner guys here where engine is given all it needs to deliver a substantial gain, but somewhere along the power train (ie in the transmission) the math stops adding up and you end up with less than the sum of your mods. Maybe my understanding is incorrect here as I don't pay close attention to the tuning threads, but I choose to believe this as it supports all this **** I am spewing.
The car is calibrated to deliver a consistent performance result, not a consistent power output. This is the platform. The drive modes are just different flavors additives.
This right here is top quality forum banter.
My understanding is that US EPA regulations don't apply at full throttle. Probably at full throttle MB gives full beans to the motor regardless of sport setting. Maybe the tranny shifts a bit differently, not sure. Throttle peddle mapping and transmission downshifting is more sedate in Comfort mode till a certain point. Once you really mash it the car does take off spiritedly.
When you floor it and keep it floored, the transmission will shift at the same points in any mode.
In the E63S, you can't use launch control unless you're in S+ so that will have a bit of an effect, but once you're rolling it doesn't matter. On the other hand, if you're doing spirited driving other than just one flat-out timed run, the more aggressive shifting makes a huge difference in how it drives. I live on a mountain road, and C vs. S+ might be the difference between being in 4th gear vs 2nd when I carve my way home. That's not with the pedal flat out, just light pressure. The car knows to stay on the torque curve in anticipation of throttling through the next curve. Huge difference in driveability, but not of that matters if the gas is floored.
