18" Winter Wheel Option For E53?
245/40 R 19 on 8 J x 19 ET 20 (Front)
275/35 R 19 on 9 J x 19 ET 49 (Rear)
I prefer to use winter tires in the winter rather than all season and, if possible, "minus 1" narrower wheels. The 2019 E450 4Matic offers a wheel/tire package that is 245/45 R18 on 8.0 J x 18 ET 43 on all four wheels. I am wondering whether there would be any problem using those wheels designed for the E450 on my car. I've called the dealer and they said they would have to check it through trial and error. The overall circumference is virtually the same, but the 18" package does change other things (closer to suspension in the rear, further away in the front, by almost an inch in both cases). I believe the E53 has larger brakes than the E450, and that could be a problem.
Tirerack doesn't offer an 18" option for my car, but the model is still fairly new and maybe they haven't gotten around to testing it.
Can anyone offer advice here? Thanks!
Manufacturer Part Number: 081762
19x8.5 et21 ... you can also run winter tire size 255/40/19
5x112
cb 66.6
Square setup should work with no issue for the front. The rear would have no clearance issue but it will poke out/extend out 20mm from the fender wheel well.
This wheel model comes with staggered option for the rear.
Manufacturer Part Number: 081534
19x9.5 et40 ... you can also run winter tire size 265/35/19
5x112
cb 66.6
For this wheel in the rear, the wheel will appear to poke/extend out 15mm from the fender wheel well. No issue with clearing the suspension component at all.
Between the two setup, I would probably suggest to go with the staggered setup.
The factory spec is 8.0J x 20 ET 20 in front and 9.0J x 20 ET 49 in the rear.
Front: 8J x 19 ET 20, 5x112 bolt pattern, thread size M14x1.5, 72.1* center bore
Part number: 1980SNT205112S72 (Carid price 10/15/19 = 312.40, free shipping)
Rear: 8J x 19 ET 43, 5x112 bolt pattern, thread size M14x1.5, 72.1* center bore
Part number: 1980SNT455112S72 (Carid price 10/15/19 = 312.40, free shipping)
The bolt pattern matches specs for the E53, the center bore is larger so hub rings would be required. I would have 245/40 Pirelli Sottozero 3 Run Flats on all four wheels since my car has neither a spare tire nor a tire-changing kit, and not even a can of sealer with the small air compressor.
Unfortunately, Tirerack doesn't offer either TSW wheels or RTX wheels.
Bobblehead, what do you think of this option?
If you go with 20 inch ... with slightly different width vs factory setup
Front 20 x 8.5 - then choose et 15 - 20. Tire size, you can choose 245/35/20 or 255/35/20
I don't recommend going with 20 x 9 for the front as you will need a real low offset to closely match the factory spec. ie. <13 offset.
In your example, say 20 x 9 et 25. It will be 18mm closer towards the suspension components.
If you go 20 x 9 et 45. Then it will 38mm closer towards the suspension components.
> I cannot say for certain whether these two examples will result in any wheel clearance issue against the suspension components, only an actual test fit can determine it at the wheel shop. In my opinion, anything greater 7mm variance would be my limit ... to be on the safe side
Rear 20 x 10 - then choose et 40 - 42. Tire size, you can choose 275/30/20 or 285/30/20
this wheel spec. will be okay and poses no issue clearance with the suspension.
The only thing you may want to rethink of this wheel is the lip. Salt water can eat into the finish of the lip esp. and the chrome finishes and what worry me also is the wheel spokes/face is moved back to allow for the lip to be there, for such construction, you have to get an actual test fit to ensure they will clear the brake caliper. Alternatively, you can have the wheel painted and then (optional) ceramic coated to protect the finish
If you have a bigger budget, take a look at the Rohana wheels too. It would be around $400 per wheel though. 19x8.5 and 19x9.5 can be had with the custom offset which can be closely matched to factory spec.
If you custom order a 20" with factory offset for summer usage, then there should be no issue to speak of. The low offset for the front is kind of a pain to deal with when looking for a pre-made wheel on the market.
https://vossenwheels.com/wheel/hf-3/
after doing a bit more research, for the front 20x9 et25 should work in most cases (it would be at the upper limit), but it is still subject to an actual test fit and the wheel is preferrably does not have a deep concave spoke face.
Front:
https://www.bbwheelsonline.com/tsw-b...5BAT205112G72/
Rear:
https://www.bbwheelsonline.com/tsw-b...0BAT355112G72/
I don't know any wheel shop in London, On. There are many in GTA you can consider.
Tires23 (Mississauga) - don't bother with the Markham location as they are much less incline to help, for some reason
https://www.tires23.com/
Toto tire (Woodbridge)
https://www.tototires.com/
Advan tire (Scarborough)
https://advantire.ca/
T1 Motorsports (Markham)
https://www.facebook.com/tonemotorsports/
Rennsport tires (Woodbridge)
http://www.rennsportire.ca/
for years and they were great last winter for me. Mine was the first E53 Cabriolet they had seen but were able to put a great package together for me.
can you disclose exactly what wheels size/brand is your setup ? so others can get an idea
here is the optimal tire size for specific wheel size
https://www.google.ca/amp/s/www.thev...d-tires/%3famp
