Exhaust Valves, Throttle
Old Feb 27, 2020 | 03:43 AM
luismatta's Avatar
W213 E63s AMG - W176 A45 AMG
Exclamation Exhaust Valves, Throttle
Hi,
My E63s has a downpipe and its tuned, apparently when you install a downpipe on these cars the exhaust flap bends and when the motor tries to open and close the flaps it gives an error because the valves aren't moving because they are stucked and then it sends a code to the ECU that makes the car's throttle to close, My car is very slow now because of this, Any idea on how to fix it without buying a new exhaust system?
Old Feb 27, 2020 | 06:10 AM
dav461's Avatar
GTR
it was discussed hundred times, use search button
Old Feb 27, 2020 | 11:19 AM
bb85's Avatar
2019 E63s
Renntech has the exhaust valve module that supposedly fixes this issues.
Old Feb 27, 2020 | 12:30 PM
Michael Khan's Avatar
There is a whole post on this. Long story short, you need to buy aftermarket vale module.
Old Feb 28, 2020 | 12:48 PM
luismatta's Avatar
So First they fixed the valve, car was like usual but eventually it bend again
Opened the valves manually and welded them open and removed the spring from the motor = no difference
Finally, pulled the valves out and reinstalled the spring on the motor and everything is fine now, The only boomer is that the exhaust is always open and loud
Old Mar 15, 2020 | 01:08 AM
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
How does your car sound with downpipes? Did you get downpipes with cats or no cats? How hard was installation?
Old Jul 2, 2020 | 09:55 PM
Mark63amg's Avatar
2018 e63 amg
i installed catless downpipes on my E63s and it sounds so much more aggressive and louder but not too Obnoxious. And I’m currently having issues with my car regarding the valves causing my car to lose power. I just order the RENNtech valve module so let’s see what happens
Old Jul 4, 2020 | 08:54 AM
kponti's Avatar
E63
So the power is back to normal as well?
Old Jul 9, 2020 | 01:52 AM
are tuners able to tune/code exhaust flaps open 100% of the time?
Old Jul 9, 2020 | 09:20 AM
Mark63amg's Avatar
2018 e63 amg
no they can’t my tuner told me they’ve been trying but just can’t crack it
Old Jul 9, 2020 | 09:21 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
I have heard the AWE valve simulators work well also. When I tune and DP i'll probably be going that route. From what I understand the problem isn't the valves themselves it's the actuators of the valves that fail after opening and closing etc.
