Does anyone here run 305/30/20 and 275/35/20 on stock 20" rims?
Old Apr 15, 2020 | 08:36 AM
nimski62's Avatar
I know they fit but was wondering how Michelin 4s perform in this size. Thanks
Old Apr 15, 2020 | 11:12 AM
mehrvarz's Avatar
19 E63SW, 18 Jeep JL, 15 Denali, 03 G35 Coupe
These tire sizes fit on stock wheels without rubbing? It’s almost time for me to get new tires. What if you use the lowering module? Do they still clear?
Old Apr 17, 2020 | 06:52 AM
apsuard's Avatar
Empty
You will not have any issues with them fitting and not rubbing. 305 on a 10” I wouldn’t advise though.
Old Apr 17, 2020 | 02:17 PM
mehrvarz's Avatar
why not?
Old Apr 18, 2020 | 08:09 AM
apsuard's Avatar
Empty
Originally Posted by mehrvarz
why not?
The wheel is not wide enough. 295 is already maxing out a 10” wide wheel
Old Apr 18, 2020 | 08:27 AM
bobblehead's Avatar
go fast grocery getter wagon
Rim width // Minimum tire width // Ideal tire width // Maximum tire width
9,0 Inches // 235 mm //245 or 255 mm // 265 mm
9,5 Inches // 245 mm // 255 or 265 mm // 275 mm
10,0 Inches // 255 mm // 265 or 275 mm // 285 mm
10,5 Inches // 265 mm // 275 or 285 mm // 295 mm
11,0 Inches // 275 mm // 285 or 295 mm // 305 mm
11,5 Inches // 285 mm // 295 or 305 mm // 315 mm
12,0 Inches // 295 mm // 305 or 315 mm // 325 mm
12,5 Inches // 305 mm // 315 or 325 mm // 335 mm
Old Apr 18, 2020 | 10:24 AM
AMG RB's Avatar
The horses are now in the barn, 2019 E63s
There's no question a lot of MB/AMG R&D was put into selecting the ideal wheel/tire combo to maximize performance and economy in this car so the next question that comes to mind for me is "what the best whee/tire combo is for max handling performance?
I'm already considering the next wheels and tires for my as yet delivered 2020 E63s and the old school in me wants to see more width on the back end for that little increase in aggressive appearance. I have read on another thread (I believe it was this or the W212 AMG forum) that another memeber switched to larger tires on OEM wheels and experienced worse handling performance.
My CTS-V Coupe rear wheels were 10" and given the clearances in the well and specs of the wheel, 305mm was the largest other Coupe owners were able to mount hence my lead-off question.
Old Apr 18, 2020 | 11:59 AM
CALBenzo's Avatar
'18 E63S AMG
If I recall correctly, Ronin made this claim after switching to 305s, so he switched back to OEM.
Old Apr 18, 2020 | 12:09 PM
bobblehead's Avatar
I am not an expert. My thought on the 295 vs 305 rear is:
305
- may look a bit better perhaps ? to each their own.
- may have a fractional more contact patch, hence better traction on straight away acceleration but most likely not noticeable in normal road use.
- one possible drawback is the higher sidewall, hence, if one is doing some fast cornering, the extra sidewall height may comprise the handling dynamics of this aspect.
- given the 295 has pretty well maxed out on the wheel width limit, the 305 may cause some unnecessary stress on the 305 tire itself over time
Old Apr 18, 2020 | 03:55 PM
kponti's Avatar
E63
I went larger tires with my W212 and had no problem. I did have some software update to correct esp sensitivity at some point
