Car wash Soap for designo selenite grey??
Old May 17, 2020 | 10:45 AM
GilsE63s's Avatar
2018 GTR
So just got my 2020 beast in selentio grey. I know not to use soaps with a shining agent but still unsure specifically which to use? Any recommendations? Is it available in your traditional car parts stores or online special order ?
Old May 17, 2020 | 01:50 PM
stratman's Avatar
2022 4 Runner Pro, supercharged and lifted Lime Rush, 2018 E63s wagon Edition 1
Hi and congrats on the new ride! I have a 2018 Night Black Magno wagon and use Meguiar's Gold Class which contains no wax additives and I also use Drx Beasley's which is a bit pricey but also works well on this type of paint. Make sure to get micro fiber towels to dry the paint and a soft mitt to soap up your new ride. This type of paint is easy to care for just don't use the cleaning mitt and towels for any other car.
Old May 17, 2020 | 02:24 PM
GilsE63s's Avatar
2018 GTR
Saw some Beasley products, which ones do you specifically use?
Old May 17, 2020 | 03:56 PM
stratman's Avatar
It's called "matte paint prescription" and it came with several products, a CD, wash bucket and two wash mitts. Kit is pricey but it contains some really good products. I ran out of the soap and started using the Maguiar's which works very well too.
Old May 17, 2020 | 06:49 PM
Munich77's Avatar
Mine: 2014 E550 4matic; Hers: 2016 CLS 400 4matic
I think you can always find Beasley’s on sale on some of the websites
Old May 17, 2020 | 07:08 PM
Wolfman's Avatar
Super Moderator
We used this; think the same as Stratman. Worked great.
https://www.drbeasleys.com/matte-maintenance-kit.html
I kept wash mitts and buckets separate for the matte paint. Microfibers to dry were used on nay car.
Old May 17, 2020 | 09:20 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I have some Adams product which I'm about out of. Considering giving Dr. Beasleys a try for the next bottle of soap.
Have a foam cannon and pressure washer and also a CR Spotless water system. The Selenite Grey is holding up well. Lately I've been using my shop vac with the hose connected to the outlet side and just blowing the car dry. Touch up with a towel here or there on the glass or the black chrome but otherwise comes out spot free.
In a pinch for my first wash I just a bit of dishwashing soap in the foam cannon. Actually worked pretty well.
I rinse the car off first with the pressure washer, foam it down, then wash off with a mitt and bucket with a grit guard, then rinse and dry. Sure beats the extra step of having to wax and polish too.
Old May 18, 2020 | 12:06 PM
JODE63's Avatar
e63 Wagon | Porsche 993 Turbo | Ferrari F355 GTS, Defender 130
Just checked out the CR spotless system.. Which one did you get? Also do you connect the pressure washer to it or just use a regular hose for rinsing? THX!
Old May 18, 2020 | 12:31 PM
E63Wagen's Avatar
2020 E63S Wagon, 2007 335i convertible (tuned to 400hp), 2011 Audi A4 Avant
I use Chemical Guys Meticulous Matte auto wash for my selenite gray magno paint. Works very well, and fairly inexpensive if you buy it by the gallon. Also use it in my foam cannon as a pre-wash
Old May 18, 2020 | 01:40 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I purchased the Basic Car Care Package with the DIC-20.
I leave the system disconnected initially for the rinsing and foaming and then put it in line for the rinse cycle. I used to leave it in for the whole washing process but was going through the filters more often than I liked, especially once my daughter started washing her new car all the time. So cut back to just the rinse which seems to work OK, provided you're doing the washing in the early morning or later afternoon while temps are lower and sun isn't evaporating the water on the car before you can rinse it off.
The pressure washer doesn't actually use that much water compared to the hose hand sprayer. I have a Generac 3200 PSI gas powered pressure washer. Has various settings on the washer nozzle grip with one for car washing and a number of different nozzle inserts. Pretty happy with it compared to the Karcher electric pressure washer I had previously.
Old May 18, 2020 | 01:58 PM
nynd's Avatar
2018 E63S
I do the same... Foam Canon (PF22) and that wash solution.
Old May 18, 2020 | 02:00 PM
nynd's Avatar
2018 E63S
Just a note.. you won't need 3200 psi.... try and it keep it set around 1000 psi or so as to not cause damage to the paint. Some think more the better... not the case.
Old May 18, 2020 | 02:02 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Right, sorry if that wasn't clear by mention of the car wash setting and car wash nozzle insert.
At full tilt with the wrong nozzle you can strip the car's finish down to bare metal !!
Old May 18, 2020 | 05:07 PM
E63Wagen's Avatar
For those of you without a water filtration system (which are pricey), I use plain distilled water as a final rinse for my washes. It's the purest water you can find, and about 6 one-gallon jugs (about 0.80 each at Walmart) is all it takes, and the rinse is perfect, with no spotting, even if you later get a drip from behind some trim.
Old May 19, 2020 | 10:04 AM
JODE63's Avatar
great! Ordered! I have the sun joe spx 3000 which has a max output of 1.76 gpm. It works great with the 25 degree nozzle. Really excited to lower my wash times!
Old May 20, 2020 | 03:16 PM
GilsE63s's Avatar
2018 GTR
How do guys wash the matt black wheels
do you use same soap you use for the matt paint or just use regular soap?
Old May 20, 2020 | 03:29 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Yep,
I foam and rinse them. I have CCBs so no brake dust. Most of the time I don't even hit them with the washing mitt. They just stay clean.
Old May 20, 2020 | 03:53 PM
E63Wagen's Avatar
I have regular brakes, so I HAVE to hit them with soap and a mitt. I use the same soap as the wash: Chemical Guys Meticulous Matte, two bucket system.
Old May 20, 2020 | 04:24 PM
GilsE63s's Avatar
2018 GTR
But I’m sure you don’t use same bucket to clean wheels then the body because brake dust residue can really do some damage on the paint.
Old May 20, 2020 | 04:57 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Top down. If you need to do brakes or the lower side of the car, do that last after the rest of the car has been done.
I have a separate mitt for the wheels. Also have a grit guard in the bucket.
Old May 20, 2020 | 05:32 PM
E63Wagen's Avatar
Nope, new soap bucket, and new rinse bucket
Old May 23, 2020 | 09:37 AM
emericr's Avatar
2021 Porsche TTS
Ill second the Chemical Guys stuff. Works really well and it smells great to boot .
