Low tire pressure error?
All my tires claimed low while mid drive today, but pressure is within range.
2018 e63s estate
2018 e63s estate
You can set the range to whatever you want because there is such a wide range of "normal" pressures depending on speeds reached and weight of passengers/luggage. Change your settings to your desired pressures.
Understand, i can change the setpoint and range, but more curious what has changed. i been running these exact pressures for over a year, and now this pops up.
maybe i will just go drift and burn these tires off... sure new tires won't have an issue.
Easy fix: inflate to correct pressure,
or, change pressure to lower in settings (if it is stilll in the recommended range, of course).
Hope this helps!
