Change your LCD Cluster Design to AMG GT63 Supersport !!
I develope / tune and code on MB Cars. Now i can offer you the newest thing. Its possible to change the Software of your actual cluster to the newer AMG GT63 4 Door / C63 Facelift.
All model years are supported. 2016-2017 models need new board inside the cluster. Newer models can be done via Software. Right now i need the cluster (at least the PCB Board inside) here in Germany. But i`m working on a remote solution in MARYLAND. There are NO ERRORS or FAULTS. Works Fine. ONLY thing is you will not see a W213 E class at Startup animation, thats because it never gave the W213 with this design.
Price is 400€ for one conversion. If you have any questions feel free to ask.
"All model years are supported. 2016-2017 models need new board inside the cluster. Newer models can be done via Software. Right now i need the cluster (at least the PCB Board inside) here in Germany"
Are you actually changing the physical board inside the car IC from a 2016?
How does that work when you have analogue dials?
Unless your saying if you already have an older Full digital dash already from 2016 then you are changing the board to flash the new firmware on to that board?
Would it not be easier to just buy a newer board from a 2020 and put that directly into a 2016 and have you code it remotely - or do you still need the PCB board to change something?
please it is possible get IC177 style to IC213 digital cluster for w205 facelift 2020 car? Thank you
