2021 E63s grinding noise when turning
Old Jun 24, 2021 | 03:04 PM
Sunbeltgolfer11's Avatar
E63s SL550 GL450
I think I saw a similar thread about noisy steering, but the description was a little different. My E63s just passed 1900 miles and has suddenly started making a grinding noise when turning sharply to the right at any speed. The sound is coming from the left front wheel or axle area. Wondering if anyone else has had a similar issue and if it was diagnosed/repaired.
Old Jun 24, 2021 | 08:55 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Fender liner interference possibly? I have 4600+ miles on my wagon with no suspension noises. I still have not seen the car go into "Glide" mode (little sailboat icon) yet.
Old Jun 24, 2021 | 09:13 PM
E63s SL550 GL450
I'd be happy if it is something minor such as that. I can't get my hand or arm in there to feel around. It's due for the rear differential oil to be changed so I'll have it looked at when that is done. It is a little relief to see no one mentioning axle, bearing or more serious issues.
Old Jun 24, 2021 | 09:41 PM
Igooz's Avatar
car
These cars have a pretty significant wheel cut giving you amazing turning radius, and at full lock the Ackerman angle results in your front tires to chirp/hop/skip but that only happens at full turn which means that you are driving at a very low speed. The other possibility at very low speed turning would be the LSD chirping at the rear.
Could it be either of these? I have experienced all of the above in other cars that I own. My new wagon only has 917 miles and I have not driven it enough to learn its personality.
Old Jun 25, 2021 | 08:00 AM
E63s SL550 GL450
I don't think it is. This was first noticed on the road down the mountain where we live on a switchback turn to the right. I was going about 35 mph through the turn when the grinding started. It sounds more like a light metal grinding, not tire chirping. I have experienced that on these roads with our GL450 when it Continental tires on it. This is a very different sound.
Old Jun 25, 2021 | 08:16 AM
E63s SL550 GL450
There was a similar issue on our SL550 a couple years ago. It turned out to be a bearing issue in the right front. Once I can get in and fixed I'll report back.
Old Jun 25, 2021 | 03:45 PM
Igooz's Avatar
car
I hope that this turns out to be very minor! I would also be interested in hearing any software upgrades!
Old Jun 25, 2021 | 08:51 PM
E63s SL550 GL450
It will be a while before I can get it in to the dealer. Wife had knee replacement two days ago and I won't be leaving the house for anything other than doctor appointments.
Old Jun 25, 2021 | 09:18 PM
HBerman's Avatar
Does your dealer have pickup service? Mine does in Raleigh if I can't get to the service dept. Just a thought.
Old Jun 25, 2021 | 11:02 PM
E63s SL550 GL450
No they don't, at least for me. I live an hour and a half away. They are in East TN and I'm in the mountains in Western NC. I'm hoping to be lucky enough to get a loaner when I can drop it off.
Old Jun 27, 2021 | 12:04 PM
haisensei's Avatar
12 CLS 63 PP
There's a factory advisory on this, my service mgr printed it off. It's the low profile tires. Nothing being damaged though it feels like it. No fix. I hate it too
Old Jun 27, 2021 | 01:28 PM
E63s SL550 GL450
Interesting. Seems odd that it would only be on one side if it were the tires. The road coming up to our community and home have hairpin curves and switchbacks galore so I have to turn to the maximum in both directions. This only occurs when turning hard to the right. Not saying it's impossible, just seems odd. Did you get a copy of the advisory?
Old Jun 27, 2021 | 04:47 PM
HBerman's Avatar
I don't believe that your issue is with the tires. The advisory talks about temps below 45 degrees and skipping on wet surfaces at very slow speed with sharp turns either left or right. Your first assumption might be right about a universal joint. I also assume that you've checked the bolts on the wheel as well for correct torque.
Old Jun 28, 2021 | 04:10 PM
E63s SL550 GL450
Wheel is good. This just sounds like a CV joint binding up, just a little quieter than an old one that has rust and corrosion.
