Instrument cluster resets randomly
I have a 2019 E Class w213
For the past 2-3 months I've noticed that the instrument cluster screen in between the speedometer and rev dial randomly goes black and turns back on with the rear seat belts screen as if it just reset.
I'm unable to recreate the issue as it's random.
I don't want to waste my time giving it to mercedes as they won't be able to fix anything unless they can see it happening.
Has anyone faced this issue or know what may be the cause of it?
I've not changed anything electronically in my car for this to happen, the car is as it came out the factory.
Thanks for your help.
The screen in between the 2 dials goes black and resets randomly.
https://mbworld.org/forums/e-class-w...stion-too.html
At any point in time, driving the car at any speed, in any driving mode, with any form of display on the center LCD screen, the screen will randomly go blank, shut off, restart and pick up where the vehicle left off, both while driving and sitting in park in a lot.
The illumination of the temp gauge, fuel level, and needles along with the center screen go completely dark for several seconds and seem to restart / reboot. This issue will continue to happen while driving sometimes several times randomly each day.
The other thing to note is at night the illumination of the center analog clock in the center of the dash also simultaneously goes out and relights. Hope this helps others.
https://youtu.be/QOvvSDCv-u0
