Wondering if anyone else had this question/ experience... I read many conflicting articles on line and finally pulled out the manual that says "requires a 2032." Funny, to check, I got smart and opened both of my 2 key fobs,.. with further confusion. One actually has a thicker 2032, and the other key fob has a 2025. The 2025 seems loose, but the FOB works fine. I think the 2025 was put in the 1 key fob I had with me during the last service. Anyway, surprised it does not matter? Oh, an surprised they charged over 10 bucks for the wrong battery.... Also, Costco sells a 10 pack of 2032 Duracell's for 8.99 on sale,... OK, just sharing!
Cylinder Head
close
- Join DateJul 2006
- LocationSeattle
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Liked:594 Times in 388 Posts
I was literally about to research this, time to change all my car key batteries. Sounds like the 2032 is the move
2032 on new style W213
2025 on older style W212
6G Schnell
close
- Join DateFeb 2010
- LocationNorth CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2021 E63S and 2025 GT63
Liked:271 Times in 198 Posts
Quote:
They are both 3V batteries.Originally Posted by Pioneer222
W213 key fob takes 2032 which is thicker and because of that has higher capacity (235 vs 170 mAh). Should last longer than 2025.
Thanks everyone, yes, I am on track with the need for the 2032 - And wanted others to be aware.. Just thought it was strange that either seems to work, and Mercedes service people don't know the difference. At my next service I will kindly ask for a complimentary correct battery
but, as aforementioned, w212 has the 2025 -- because it's thinner and it fits
2032 will not allow the fob cover to close.
E634Me
close
- Join DateMay 2017
- LocationSouthern California
- Vehicle(s) I drive2018 E63S AMG
Liked:605 Times in 417 Posts
Mainly it's just a dimensional difference in thickness. Both are 20 mm in diameter, the 20 in CR20XX, but the CR2032 is 3.2 mm thick whereas the CR2025 is 2.5 mm thick.
Both are 3 V lithium cells but the CR2032 does have a slightly higher amp hour capacity due to the increased thickness.
I'm 99.9% sure I replaced my fob batteries with CR2032 cells. Didn't consult the manual, just replaced with like kind.
W205C43PFL
close
- Join DateDec 2019
Liked:6,314 Times in 5,479 Posts
The W213 keys do take a CR2032 from factory I think? It is the previous model MBs with the older style key that takes CR2025. ...I think. CR2032 I remember were watch batteries or the Tamagotchi my kids used to play. Originally Posted by E634Me
Mainly it's just a dimensional difference in thickness. Both are 20 mm in diameter, the 20 in CR20XX, but the CR2032 is 3.2 mm thick whereas the CR2025 is 2.5 mm thick.Both are 3 V lithium cells but the CR2032 does have a slightly higher amp hour capacity due to the increased thickness.
Explore
