E63s Spark Plug Change
Old Nov 26, 2021 | 09:14 AM
ScreeminE63s's Avatar
Mercedes E63s
Does anybody have a DIY for this? C63 looks to have a lot more access than the E63.
Old Nov 26, 2021 | 09:25 AM
bobblehead's Avatar
go fast grocery getter wagon
https://www.ngkpartfinder.co.uk/cata...SS/2020/12437/
I had mine changed out at 60,000km at the dealer. The OEM plugs are simply NGK brand.
Old Nov 26, 2021 | 09:26 AM
Mercedes E63s
Finding the spark plug part number is the easy part. Just wondering if anybody had the process to do it? Lots of things in the way… ECU and driver side has coolant reservoir for intercooler… etc.
Old Nov 26, 2021 | 10:11 AM
bobblehead's Avatar
I know. I tried to get my independent shop to do the job and the guy simply told me that looked to be a lot of unbolting of parts/components so he advised me to take it back to dealer in which I ended up paying a lot more $ for this 'supposedly' straight forward job.
Old Nov 27, 2021 | 06:52 AM
Beer_Bandit's Avatar
CLS500
What year?
This might help....
Old Nov 27, 2021 | 06:58 AM
Mercedes E63s
2018 E63 with the M177 engine.
that video is on the 5.5L.
Old Nov 27, 2021 | 07:01 AM
CLS500
Try this one:
Old Nov 27, 2021 | 07:11 AM
Mercedes E63s
Saw that one already. While similar - that is a C63 and only has the air intake ducts in the way which remove easily. The E63 has much more in the way like the ECU and coolant reservoir.
thanks for the help.
Old Nov 28, 2021 | 10:52 PM
INNOVATE_1's Avatar
C6Z
I took mine to an Indy shop about 2k miles ago.. paid about the same premium as if I had gone to the dealer. The dealer was actually my preference but I needed the car done on the same day, dealer was booked out.
Old Nov 29, 2021 | 02:13 PM
kponti's Avatar
E63
Originally Posted by Beer_Bandit
Shouldn't these cars be indexed??
Old Mar 13, 2022 | 02:33 PM
WIKDWGN's Avatar
2018 E63S AMG Wagon, 2020 Audi R8 Performance
What's the recommended interval for plugs on this engine? It looks like a bit of a job with all the stuff in the way. You can barely see the coil packs, let alone being able to remove them & get to the plugs.
Old Oct 11, 2023 | 12:50 PM
18e63's Avatar
2018 E63 S
The workshop sheet says every 5 years. However, my Indy shop said these should be good for 100k. Not sure who to go by.
Old Oct 11, 2023 | 01:36 PM
L M's Avatar
L M
'20 E63S
My dealership changed mine under my PPMP at about 60K. This tells me that is what AMG is recommending.
Old Oct 11, 2023 | 02:01 PM
18e63's Avatar
2018 E63 S
Do you think the recommendation is based on miles or age? I only have 22k on my 2018.
Old Oct 11, 2023 | 03:20 PM
bobblehead's Avatar
AMG is a high performance vehicle, to get the most out of it, the spark plugs should be changed at an earlier interval than your ordinary lower horsepower vehicle, per se, imo.
From my first change at 60,000km, I asked for the old ones back and they all showed signs of wear but not to the point of excessive wear which can impede performance. In the end, it is likely up to the individuals.
Old Oct 11, 2023 | 06:20 PM
Gsav's Avatar
MB E63S
I felt a subjective change in acceleration and idle smoothness when I had an Indy change mine @ 34k. It’s a big job for dyi
Old Oct 12, 2023 | 07:16 AM
zukmeister's Avatar
2023 E63S AMG - Grey Magno
what does a job like this cost? Just curious
Old Oct 12, 2023 | 07:49 AM
L M's Avatar
L M
'20 E63S
I was told it's a $900 + tax job. I sure was glad I got the PPMP.
Old Nov 3, 2023 | 10:34 PM
abdulla63's Avatar
C63 2010 AMG, G63 2019, E63s 2018, Raptor Gen 2
Talking E63s Spark Plug Change
I changed them 2 days ago, car done 59,000km took 3hrs approx.
its not a DIY. On the left engine bank(driver side) the mechanic had to remove the intercooler reservoir (aux reservoir) just pulled it and popped up. and removed its bracket underneath, then had to unscrew the bolts for the high pressure fuel pump then moved the rails and get access to the ignition coils. Its a tight space,
the left engine bank (pax side) had to unplug the ECU cables and unscrew the bolts holding it, moved it out of the way and then tried to get to the ignition coils.
here in the UAE the labour costed me 41$. with engine oil changed as well. . lol.
obviously the dealer would've charged me way more than that.
the car ran much more smoother and a noticeable difference in performance.
Attached Thumbnails E63s Spark Plug Change-screenshot-2023-11-04-6.30.32-am.png
Old Nov 4, 2023 | 06:36 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
its a LOT to DIY. i wouldn't attempt it.
DI cars are hard on plugs. Do it every 60 at the latest. Jurys out on how much indexing matters, but any MB specialist will do it and have their own way of doing it.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Nov 4, 2023 | 02:51 PM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
As these 213s age , I'm guessing a diy spark plug thread will eventually surface here. Haven't heard much about indexing these like the m157 ? Sounds like it involves removing quite a few items to access.
Hopefully some more info surfaces as the 50-60k mile marker becomes more common here.
Old Nov 4, 2023 | 03:18 PM
abdulla63's Avatar
you mean 50/60k kilometers
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
