Heated steering wheel RETROFITTABLE to 2018 e63s?
Old May 9, 2022 | 11:16 PM
GTS daddy's Avatar
2015 Macan Turbo
As the title says, it seems that I have discovered on this forum that the 2018 e63s (for the US market at least) does not have a heated steering wheel as an option. I have also discovered here that the 2019 e63s does have a heated steering wheel option. On that note, has anyone successfully retrofit a 2019 e63s heated steering wheel to a 2018 e63s?
Old Feb 29, 2024 | 06:59 AM
eqs88user's Avatar
EQS SUV 580
Since E455 there is a steering wheel heating button in MBUX climate menu
Old Oct 8, 2025 | 09:34 AM
jaha1313's Avatar
e63 Wagon
I am attempting to do this now.
I have an aftermarket wheel with heating element installed on the car. And then a clockspring from 2015-2017 S550/ S600. This is the exact same clockspring as in 2018 E63 except it has the toggle switch on the end of the stalk height adjustment, that turns on the wheel heater.
However, I can't find someone to program it. I have had 2 different shops try and no dice. People on here say it's possible but I cannot prove that at this moment. The search continues.
The 2018 E63 uses the Command system and not MBUX
Old Oct 8, 2025 | 06:13 PM
figuwx's Avatar
2018 AMG E63s Ed1
to have heated steering REQUIRES that the steering column have the wiring and associated hardware for the heated steering wheel. Also needs to be coded.
