AMG E63 S Milage
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
The issue is air pressure....at 10psi below the recommended cold fill levels, you were concentrating the weight on the inner portion of the contact patch, which generates wear and heat which ultimately led to your sidewall failure along the belt junction
I know its a "comfort" thing, but the s/w213 is a heavy car, and should have tires inflated as specified, which results in a somewhat stiff ride.
There were a lot of recall campaigns on the 2017 and 2018. If that is the year you are considering, look for documentation they have all been completed. The most important one is the retrofit of protective screens over the intercoolers. One that a lot of people like is the retuning of the suspension response.
SilverE5588 (05-17-2022)
go fast grocery getter wagon
