Main battery replacement
Old Mar 25, 2023 | 02:38 PM
kvirikadzed's Avatar
Been getting low battery for a year now ,
want to replace main battery on 213 e63
Wonder if anyone has tried any other battery outside of stock one ? Has one replaced about 2 years ago and it started to show alerts after about a year, now for past 7 mont I’ve had low battery warning .
thanks
Old Mar 25, 2023 | 02:57 PM
bobblehead's Avatar
go fast grocery getter wagon
I had mine replaced under warranty at 3.5 yrs in service time.
Old Mar 25, 2023 | 04:28 PM
Ed99's Avatar
E63s AMG
Would there be a warning message for low in battery? Just curious.
Old Mar 25, 2023 | 05:14 PM
W205C43PFL's Avatar
thanks
If you still have new car warranty this should be covered though as long as the battery fail the battery test. I also think maybe there is a warranty on the replacement as well that happened two years ago?
Old Mar 25, 2023 | 05:15 PM
W205C43PFL's Avatar
I believe it would be "Stop, leave vehicle running" "Leave vehicle running" or "12V battery, see operator's manual"
Old Mar 25, 2023 | 07:14 PM
atl 2 chi's Avatar
Current :2018 E63S and a 2018 GLE 63S . Prior, CLA 250, C450, 2017 AMG C63S
That is what my display continued to show so I had it replaced.
Old Mar 26, 2023 | 09:49 AM
W205C43PFL's Avatar
Hopefully no more error messages : )
Old Mar 26, 2023 | 01:14 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
I had the battery replaced on my 2021 E63S last week, There was a weak cell that was lowering static voltage after 1 day of inop. This was replaced under warranty after the dealer got permission from MB to do the replacement.
Old Mar 26, 2023 | 01:22 PM
W205C43PFL's Avatar
Usually it is the starter battery causing electrical glitches but auxiliary battery cannot be neglected as well as I heard it can affect start/stop and even transmission shifting behaviour.
Old Mar 26, 2023 | 03:57 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
There's no aux battery in W213.
Old Mar 26, 2023 | 05:22 PM
W205C43PFL's Avatar
Wait, are you sure? I could had sworn there was one.
Old Mar 26, 2023 | 05:23 PM
W205C43PFL's Avatar
I found this video, maybe auxiliary battery is market dependent?
youtube.com/watch?v=wvzuaj233J0
Old Mar 26, 2023 | 06:09 PM
imack's Avatar
2020 AMG E63S Wagon, 2021 Subaru Outback Limited XT
Or maybe generation dependant: https://mbworld.org/how-tos/a/merced...battery-389645
Ivan. MacKenzie.
Old Mar 26, 2023 | 06:12 PM
imack's Avatar
Excerpt from the 2020 E-Class Wagon Operator's Manual:
Battery for the transmission???
Ivan MacKenzie.
Old Mar 26, 2023 | 06:21 PM
W205C43PFL's Avatar
Ivan MacKenzie.
That explains why auxiliary battery malfunction changes the shifting behaviour of the transmission, interesting find, never occurred to me to look in there.
Old Mar 26, 2023 | 06:22 PM
W205C43PFL's Avatar
Ivan. MacKenzie.
As you can see from the youtube video posted above, it is also on W213 s, but problem is not sure if it is market dependent hence why some W213 might not have it?
Old Mar 26, 2023 | 06:47 PM
imack's Avatar
The video shows replacement of something he calls a "voltage regulator". It's certainly doesn't look like a battery: https://mbparts.mbusa.com/oem-parts/...e-205905341480 , and it doesn't show fitment for W213.
I remain confused.
Ivan MacKenzie.
Old Mar 26, 2023 | 07:15 PM
W205C43PFL's Avatar
I remain confused.
Ivan MacKenzie.
Same but even in the C-Class the auxiliary battery is really a capacitor to add to the confusion?
Old Mar 26, 2023 | 08:03 PM
taphil's Avatar
Yes, that capacitor voltage regular replaced the functions of an actual AGM lead acid aux battery located in the trunk.
Old Mar 26, 2023 | 08:06 PM
W205C43PFL's Avatar
Yes, that capacitor voltage regular replaced the functions of an actual aux battery.
I see, if that is what you mean by not having an aux battery in the W213 then that clears up the confusion, MB calls it the auxiliary battery still although it has become a capacitor for a while now since W205 C-Class I believe?
Old Mar 26, 2023 | 09:40 PM
NickTheStick's Avatar
W213 E63s
I recently had my main battery replaced on my 2018, after having warning messages for several weeks. It failed the Xentry test and cost me $295.xx + labor. No more warning lights.
Old Mar 26, 2023 | 09:53 PM
HBerman's Avatar
Nope! There is a capacitive store on the E63S, but no auxiliary battery.
Old Mar 26, 2023 | 10:44 PM
I’ve had it replaced one allrady at 32 k under warranty now at 52k mi , are there any alternatives to stock batteries ? Replacing should not be that hard .
Old Mar 26, 2023 | 10:46 PM
how much was labor ? Soiling like I need new one as well.
Old Mar 26, 2023 | 11:25 PM
taphil's Avatar
Battery costs around $200 and takes 5 minutes or less to replace.
