Main battery replacement
Old Mar 27, 2023 | 12:22 PM
NickTheStick's Avatar
W213 E63s
Originally Posted by kvirikadzed
how much was labor ? Soiling like I need new one as well.
$175, which include the Xentry testing *eye-roll*
Old Mar 27, 2023 | 10:25 PM
W205C43PFL's Avatar
Originally Posted by HBerman
Nope! There is a capacitive store on the E63S, but no auxiliary battery.
Thanks for confirming, I stand corrected then.
Old Mar 27, 2023 | 10:27 PM
W205C43PFL's Avatar
Originally Posted by NickTheStick
I recently had my main battery replaced on my 2018, after having warning messages for several weeks. It failed the Xentry test and cost me $295.xx + labor. No more warning lights.
Glad to hear it is fixed.
Old Mar 28, 2023 | 06:08 PM
kvirikadzed's Avatar
Contacted my FCP euro and went with following battery
Group 49 H8 Battery - Odyssey Performance 49-950
last one from MB that was replaced with warranty only worked for 8-9 month and for the past 6 month has “start engine warning “
I’ll see how this OEM alternative stacks up against stock one , was tempted to try much lighter lipo based battery but not sure if our electrical is compatible with it .
Old Apr 4, 2023 | 10:09 AM
6D6H6's Avatar
‘18 E63S Wagon
it's amazing how hard i've had to dig to just find the right battery to fit the 213's. Is H8 AGM the right one to get? some places have said H9, others H7.
Every store has some form of 'vehicle battery finder' but for whatever reason the w213 e63's either aren't in the list of cars or if it is the result comes up with no match. Even though clearly every manufacturer makes an H8 AGM. The merc dealer wanted $550 to replace the battery, which is laughable given they're around $200 and takes 5 minutes to change.
Old Apr 4, 2023 | 11:33 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
H8 AGM is easy to find at Costco or any auto parts store.
Old Dec 21, 2023 | 12:31 PM
  #32
jimh6's Avatar
3er
I apologize for a dumb - reasked question but it seems to have mixed opinions. Can you just drop in a nice new H8 from Costco (Interstate who makes the MB battery) or any other store without reprograming OR does it need programming. I've talked through this with my service advisor who I do trust. He said the w213 unlike some before needs a flash but did kind of smirk. He THINKS it's about optimizing battery life. Given the cost of a battery and hourly rates, I'd just blow off reprograming because it's have the cost of the battery. Thoughts?
Old Dec 21, 2023 | 12:47 PM
  #33
Keith66's Avatar
2018 AMG E43
There are no dumb questions, only dumb answers.
My car (E43) by default is setup for a H6 and there is a spacer in the battery tray that's stamped with something like "remove when installing a H8 battery". Yes a H8 fits. Keep in mind that a H8 weighs about 12-15lbs more than a H6, if that matters to you.
Here's my opinion of the battery programming/reset (take it for what it's worth):
https://mbworld.org/forums/e-class-w...ml#post8892619
Old Dec 21, 2023 | 01:08 PM
  #34
jimh6's Avatar
3er
I tend to agree with your logic there. Just felt the need to ask. I might feel different IF I had codes or something. I had the car in for Vented Seats sucking (which they just do) and part of their diagnostic showed low power for the function and it was being managed by shutting down the seat blowers. Sooo while the battery isn't causing any major issue or throwing errors, it was not up to snuff.
Old Dec 21, 2023 | 04:02 PM
  #35
taphil's Avatar
Replacing the battery on this car is the same process as replacing a battery in a flashlight. Take old battery out, put new one in. Move on with life.
Old Dec 21, 2023 | 04:08 PM
  #36
Keith66's Avatar
2018 AMG E43
Agreed. I think the rest of the story is a method to keep milking the "dealer-only service" cash cow.
