Accuracy of Boost, HP, and Torque Indicators
I have had my 2019 E63s for just under 3 months and like other AMG models I have it has displays that show HP, Boost, and Torque. I tried mine today and could not get either the HP or Torque above 500. I was in sport + mode accelerating onto a highway with pedal depressed all the way. Not that it should matter, but I was at about 6,900 feet elevation at the time. What am I missing? Thanks.
Obviously, the image below is in the garage. I did not take one while trying this on the highway :-)
Received 2,457 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
The other forum was for C63
I checked that other thread out and saw it was for C63. The numbers they discussed were in the right ballpark for a c63. I had a GLC 63 (2021) and it seemed just about right. I also had a GLE63s and the numbers seemed right for that as well - it was a 2019. I am not going to worry too much about it but it does seem wrong. I have had screens on other cars that were much worse than this :-)
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
The model can 100% be used to determine if your car is running correctly, but I don't believe it is truly accurate. Personally I can tell the difference if I put bad gas in my car. That said, prior to my PTG tune the numbers I got were accurate to stock numbers, and now I peak at 758hp which is around what my tune should be doing at the crank.
Yes, I would have expected just a bit north of 600 for HP and about 20 over that for torque figures on my stock 2019 E63s. It it read that, it would be consistent with the other AMGs with that screen that I have had. The car 'feels' like it it running fine though.
Received 3,823 Likes
2019 C63CS
As I said in the thread linked above for the C63, the numbers displayed are calculated and not actual numbers. Boost pressure should be pretty accurate, as that is measured. These displays are a good indicator to see if the engine is performing as it should. Lower hp/tq than expected is the first indicator that the engine might be in soft limp mode, and if boost isn't at max under WOT, that's a good indication that there's a leak somewhere. Having said that, in your case you were at ~7000 ft. While forced induction engines can compensate for altitude as long as the turbochargers can support the additional air volume and shaft speed, in reality for boosted street cars you'll see a power loss eventually at higher altitudes, especially since our turbos are smaller for better low to mid range response and generally fall flat at the top, but our engines have virtually no turbo lag in exchange.
Yup the boost looks OK. I was at WOT. So do do you think the about 15% lower numbers on my car are due to Altitude? The other cars I noted were also at this altitude so I don't think that is it. In terms of limp mode, it seems to pull too strong for that.
2019 C63CS
It's possible. I honestly don't know how much these engines lose for every 1000 ft, but for reference a naturally aspirated engine loses about 3% of its power for every 1000 ft, so at 7000 ft that's about a 21% loss. You are definitely at less than that, so it's plausible. I would have hoped for a smaller loss, but but as said, the smaller turbochargers run into constraints at the higher end.
Thanks for the reply. I appreciate it. As I said, I max out both torque and HP around 500 with is in the 15% ballpark. The car feels fine. It pulls very well. The only confusion I have is that my other cars did not show this loss (at least on the meter) at the same altitude. A test I might do next time I go to the "big city" is see how it does down there. It is about 1,000 feet lower so, I should see a slight increase on the gauges. BTW - I agree, this car seems to have the lowest turbo lag of any I have had.
2019 C63CS
Probably will be hard to tell with just 1000 ft difference. I live at sea level and regularly drive up to about 2000 ft on my canyon runs with my C63. Can't really tell a difference in power by the seat of my pants and hard to make out any material difference in the gauges. Definitely noticed a power drop with my previous naturally aspirated car, though, even at those elevations. It's been a while, but I sometimes head down to SoCal and drive up in the canyons above LA at 5500 ft. Again, my previous naturally aspirated car was noticeably down on power at those elevations, but from what I remember with my C63 the subjective difference was much less, but then it also has about 60 more horses than my previous car and almost twice as much torque. My previous car had a high revving V8, so to make power it had to be wound out and essentially kept above 7000 rpm.
No problem. Thanks for the information. I am wondering how different the M177 in my car is from the engine that was in my 2021 GLC 63. I have started using an E10 gas which is permitted according to the manual and wonder if that could have an impact. Also where I live, there is no such thing as 93 octane gas. At these altitudes 91 is the best you can do. I am going to see if I can find some 91 octane that is not E10.
The hp and tq on my display goes to the max 600 in comfort mode when I mash the pedal, not even to the click, driving uphill in a straight line.
2019 C63CS
Ethanol technically produces more power, because it burns faster and more effective than gasoline. However, a gallon of ethanol has less energy content than gasoline, so mpg is lower with ethanol. E10 doesn't make all that much of a difference. The ethanol in E10 acts mostly as octane booster and oxygenizer, but you might have noticed that some hypercars, specially Koenigsegg require E85 to make the rated power. They make significantly less power on other pump gas. Ethanol is also highly corrosive, so the fuel system has to be designed to support it. The M177 like most engines today is designed to support up to E10. If you go higher you have to replace the fuel pumps and some other stuff. The EU spec engines are tuned for the higher octane in Europe. US and Europe uses different octane ratings. Europe use RON and US uses AKI. 91 AKI is about equivalent to 95 RON, which is only midgrade. Premium in Europe is 98 RON, which is about equivalent to 93/94 AKI. I did European Delivery with my C63 and they retuned my engine for Europe and then when it arrive in the US they tuned it for the US octane. This was specifically called out in the paperwork I got.
Here's a good video from Engineering Explained if you wanna learn more about Ethanol vs Gasoline.
Cylinder Head (06-01-2023)
Yes, I think the elevation might have an impact. I am just wondering why it did not with my previous AMGs -- a least from the HP/Torque gauges in the cars. I tend to think/hope, there is nothing wrong with my car because it 'seems' to run great otherwise. BTW the gas I have been using is from Sam's club. I may go back to Shell if it is not E10. Otherwise it is not worth the price difference.
2019 C63CS
https://www.aisleofshame.com/is-sams-club-gas-top-tier
Thanks. Based on this, I will likely go back to Shell. I read the article in the link and it said Sam's has their own package, but that does not by itself seem to make it a top tier gas.
I use Shell too but many folks here use Costco which forum member superswiss verified is too considered as Top Tier gas.
Can you do me a huge favor and confirm where on your 2021 e63s where the boost and hp gauge tops out? I am dealing with what seems to the be classic exhaust flap issue but the dealer is telling me everything is fine. My boost gauge is only going up to 1/3 of max and HP is topping out at 350 hp.
I.T. Guy (06-25-2024)
