Hello,
I cannot find any information on the tightening specs for the front caliper bolts.
Does anyone have access to WIS that can see this info? FCP website states 80nm + 45 degree turn. It seems low.
If there is a service guide for the entire brake rotor replacement procedure, that would be welcomed.
Thanks!
Thanks!
Thanks!
did you ever find?Originally Posted by W213E53AMG
Hello,I cannot find any information on the tightening specs for the front caliper bolts.
Thanks!
so interesting question here. part # 0199907901
i replaced them when i just did my front brakes again
you can see here they quote 80nm + 45° through FCP Euro
https://www.fcpeuro.com/products/mer...01#description
i asked my dealer to confirm with a tech through the WIS what it says and he asked for my VIN and then told me 150nm + 45°
i asked the guy again for a 2020 E53 and he said yep 150 + 45. that sounds like it's absurdly high and clearly wrong to me. i torqued them to 80nm + 45 which worked out to around 100ft-lbs if my torque wrench was correct. they felt quite snug and secure. surely 150nm (approx 110ft-lbs) would be crazy PLUS 45 degrees. does anybody have access to the WIS who can confirm for me
C63fora2w1
close
- Join DateOct 2016
- LocationDestin FL
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2018 E63 AMG S
Liked:80 Times in 62 Posts
Thanks!
The correct torque is two uga dugga's Originally Posted by W213E53AMG
Thanks!
yossarian1
close
- Join DateAug 2025
Liked:27 Times in 20 Posts
Quote:
I deleted an unfunny joke...Originally Posted by C63fora2w1
I found this online. I make no guarantees as to accuracy but seems to match what dealer tech said. I'm kind of shocked it's that high. I guess I should tighten it more
Currently Active Users (1)
