Newbie Questions on Map Updates and Auto Lock
Hi all,
I've had my 2020 E63s wagon for about a month and have learned a lot from you all so far! Two things I can't seem to sort out are the map updates and the auto lock function.
Cars been trying to download and install the v24 map update for weeks now and it still hasn't completed. Does seem to be making progress each time I check but it seems to be holding at 98%. Is this expected? Any way to force it to complete already?
Other thing I can't figure out is the auto lock setting. Setting is turned on but car doesn't auto lock when I'm driving or when I walk away with the key in my hand as I would expect. Any ideas?
Thanks!
The latest one is actually V25. It just came out. Downloaded it this morning and inserted the SD card in the car. Will start the installation next time I drive it. The manual download is done from the web portal.
https://www.me.mercedes-benz.com/pas...ap-update.html
The auto lock as mentioned above only locks the car once you start driving off and the wheels turn faster than walking pace. There's no auto lock when walking away from the parked car. Instead you get a notification on your phone after a few minutes if you forgot to lock it and you can lock from the app.
If you get "Storage medium not found", then the USB stick is either not empty, not using MBR or appears to the system as a hard disk instead of as removable media.
1. Win10 laptop with latest chrome
2. Sign-in to Mercedes Me before downloading and launching the Mercedes Download Manager
3. Re-format my USB stick 3x with NTFS
4. Start nav in the car and insert USB stick with downloaded updates
4. Turn-off auto update of maps in the car
5.Drive around and let map update v25 fully load
So all seems to be updated now and once using the built in maps was enough to convince me I'll likely never use it again and will just use CarPlay with Waze instead. That's fine i bought this car for the biturbo v8 not the tech!
