B service
So my 2021 E63s is due for a “B” service. At least, that’s what I think it is. Besides new oil and filter, is there anything else that’s really recommended at this interval? I’m at 14k miles now. My dealer has three packages: economy, preferred and premium and they all seem like garbage add ons. The add ons include everything from alignments to changing windshield wipers, to “AC evap cleaning” and sunroof maintenance. At this particular dealer, the cost is ranging from $400-900. The $900 includes everything including the AC service and sunroof maintenance. None of the services includes brake fluid service which is $230.00 and really the only thing I am thinking about adding on.
TLDR: besides oil and filter, do you folks recommend anything else? How about brake fluid service? Whats a reasonable charge for the B service? The brake fluid service is a separate charge at $230 and is “recommended” to be done at 2 years.
Other than that, in cabin filters are the other item to change out if you like.
Brake service can be considered as well. Just have the pads cleaned and calipers serviced.
https://www.mercedesbenzofstpaul.com...ar-st-paul-mn/
There is nothing under any of the three packages that lists brake fluid exchange as something that’s included.
$110 is pretty cheap for brake fluid flush. B service costs me over $200 more than A service, and brake fluid flush is the only difference.
I just looked at my old receipts. The first B service on my GLC43 was $330. The first really expensive service is the B service plus transmission fluid change, but that was still under $900.
I'd been lax on doing it for my F-250 which I don't drive that much these days, and as a result the accumulated gunk in the lines caused a clog near the master cylinder and cost me a bit to be repaired. Could have done it myself I suppose, but didn't feel like getting into it. But this triggered me to get with the program and do the other cars which were all a bit over due as well.
Super easy and while I was at it I also replaced the brakes on my Honda mini-van which were getting a bit worn. Hardest part was getting my wife or daughters to come to the garage and spend a few minute pressing the peddle for me
.At shop rates and paying huge mark-up on the brake fluid, $220 is probably not crazy at a Mercedes dealer. Jiffy Lube or some other similar outfit will charge less than $150 I'd bet, but I wouldn't let them near my CCBs.
- Mercedes-Benz Synthetic Motor Oil Replacement
- Replace Genuine Mercedes-Benz Oil Filter
- All fluid level checks and corrections are dependent on factory-recommended service intervals for your vehicle’s year and model
- Tire inflation check and correction
- Brake component inspection
- Reset maintenance counter
- Brake fluid exchange
- Tire inflation check and correction*
- Wiper blade replacement*
- Replace air condition cabin filter
- *Dealer Recommended
Mercedes Service & Maintenance | Mercedes-Benz USA (mbusa.com)
from above website these add ons = replace Cabin filter + Replace brake fluid.
you need to get something like attached MBUSA Doc for your car from MB (I got this one on this forum somewhere)
NOt a huge difference and why they charge double is crazy at some dealerships.
FYI mine is A = $199
B = $299
Which is not bad figuring supplies just for an oil change average price is about $75-90.
How could this car be passed as a CPO is beyond me. My friend fixed the module in the trunk and his dealership wrote it up as a courtesy. I contacted Mercedes corporate about the other issues and Westwood had to fork over a check for all the services and missing components. Was close to $1500.
Westwood and Boston dealers are known to inflate the **** out of the bill. Also, quality of work isn’t guaranteed. Shoot me a message with your Instagram handle, I’ll direct you to the right direction for all of your amg needs.
Goes for anyone within Boston area vacinity.
DO NOT GOTO HANOVER, WESTWOOD, BOSTON stealerships!!!
I've got my A3 next year, which is also very pricey as it includes new plugs. I will be shopping that one around, including a couple legit independents...although I won't get too creative with it as I have the factory extended warranty.
I honestly don't recognize the guy in the mirror, taking my car to a dealer (or anyone) for basic services. This is what life, kids and in-warranty vehicles will do to you.
