Patched & plugged PS4S MO1
Old Jun 26, 2024 | 11:40 AM
LMinn's Avatar
2023 E63s Sedan, 2020 E53 Sedan
So I found a slow leak in my rear passenger tire yesterday afternoon, I've already gotten it patched with tire patch + plug. Now I have to reset the PS4 pressures (36 all around) as they did manufacturer rec but I'll do that once they cool off.
One of these things:
Anyway, what do you guys think? If I'm doing drags or track. is it still safe? I've never had to have a tire patched before.
Old Jun 28, 2024 | 10:31 AM
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
I would think it is OK as long as it was done properly and doesn't leak. Definitely watch the pressure on that tire.
Old Jun 28, 2024 | 11:03 AM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I once got a flat in the rear tire of one of my track bikes immediately after having the tire mounted. Picked up a screw outside the shop where the tire was mounted. Turned around and brought the bike back into the race shop and had it patched with a plug.
Was a bit worried about using that tire for races that weekend thinking of the forces acting on the plug while the tire is spinning at 130+ miles an hour with all the wheel spin that's happening on the way up there. Wasn't a problem.
I've had a few other tires patched for normal road going use, both motorcycle and auto and have never had a problem with them.
Old Jun 29, 2024 | 06:04 AM
LMinn's Avatar
I also asked some friends off the forums (IRL) and they say the same thing. I really appreciate that, thank you. I will definitely be keeping a close eye on that tire.
I ran over a drywall screw in the road apparently. Can't predict that kind of stuff, damn.
