Advance light package not working?
Old Oct 31, 2024 | 10:04 AM
18w213weeeee's Avatar
I've had my 2018 longroof 2.5 years now. I noticed a few months ago that the high-beam-on display has changed from the very cool, bringing up in the center and fan out, to a standard on/off across the whole spectrum like any random car. I can't seem to find any settings in the UI that would have changed this. Did something break? I've never had them coded, US spec car.
Old Oct 31, 2024 | 10:22 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
Activate ILS by pushing left control stock on steering wheel forward. Dashboard should show light symbol with an A in it.
Old Nov 1, 2024 | 02:28 PM
So I see now that the lighting switch on the dashboard needs to be set to auto for this to work. I did test it out last night, and the auto dim works fine (too well, in fact) but the auto-high beam after is quite laggy and a number of times simply did not come back on when it clearly should have, and I had to manually move the stalk to get it to function again.
At any rate, I'm considering Euro lamps and programming to go with it; the true capabilities of the multibeam headlights are amazing.
Old Nov 1, 2024 | 03:02 PM
taphil's Avatar
I don't know it you need to change out the headlights, but coding for full ILS makes the headlights a lot better.
Old Nov 2, 2024 | 12:54 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
The coding will work with US headlamps. Makes a huge difference. Don't know what the Euro lamps bring - different marker light color maybe?
Old Nov 2, 2024 | 04:53 PM
Euro lamps look better IMO. They remove the amber marker embedded in the assembly.
