Difference Between the Brake Systems
I have recently purchased a 2019 E53 coupe and I am kind of confused about the brake systems. My car currently has the AMG silver Braking system which is good however I am wondering if they are better alternatives that are OEM and really what is the AMG silver Brake system since there aren’t much information out there.
4-piston front and 1-piston rear calipers
Front axle: brake disc measuring 14.6 inch, internally ventilated and perforated with 4-piston fixed caliper
Rear axle: brake discs measuring 14.2 inch,internally ventilated 1-piston floating caliper
Grey-painted brake calipers with“amg” lettering
https://mbworld.org/forums/attachmen...921d1621976969
I am not sure if the E 63 brakes will fit but it wasn't available as an option on the E 53.
https://www.fcpeuro.com/products/mer...mbo-2304211212
Thank You very much for this, and correct I actually spoke to the owner and he mentioned that back when he ordered it there was no higher brake options. Maybe they have added it on the newer models.
Wow I see thank you very much for the detailed explanation. So strange to not find a lot of info over the 53 models And for sure It is definitely better. Also looks so much nicer. BTW love your rims.
It doesn't seem so, the 53 will just get one brake option while the full fledged 63 models gets more options.
This is the same on the new CLE 53 apparently so they probably have no plans to change that.
See Brake options
For rears, keep with them as they are the same with the E63 which has taller pads and larger surface friction.
I like the progressive braking feel of the 6 pot more than the snappy brake feel from the 4 pot. Using Powerstop Z23 ceramic pads as well, little brake dust and clean rims are goodddd....
looks fire btw. Thanks for the info
