Permanently disable eco start by disconnecting battery cable?
Can I just leave this wire disconnected or is it important for anything else? I haven't noticed anything else not working...
if you're curious, scan your car for soft codes/faults that have been generated due to that wire being unhooked.
To OP, you disconnected the Hyundai battery sensor that reports the battery voltage back to the ECU, since the ECU cannot determine if it is safe to use the start/stop function (ie. low battery charge and with the risk of not being able to start again), it disables the start/stop.
If you really want to disable start/stop, there are scanners and of course one time use OBD modules to disable it or set as last known state.
I also had two TCM codes which may be unrelated; U014800 - Implausible data were received from drivetrain and P060AC02 - Internal temperature sensor 2 of the control unit has a malfunction. There is a general signal fault. Hmmm. I'm actually at the dealership right now having an alignment performed and a software update for the drivetrain as there is an active recall relating to it. Perhaps these things are related? I will start scanning the car regularly to see if these codes come back.
I also see from that thread that it can harm battery life. I'll leave it connected.
Yes, I've seen those. I might pick one up in the future. I wasn't really trying to disable the start/stop though. This was just a little accidental discovery.
I have an Alltel scanner. I don't have the model on hand. I'll do some research and see if it is possible to do so with it.
I never noticed the stop start thing because my tune already had it coded out!
EDIT: Oh wait I'm in the 213 section! My experience was from the 212 so YMMV and I edited out my "vote".
