EZS EIL problems
Old Jul 26, 2025 | 02:52 PM
bluelectron's Avatar
2011 E63 AMG
EZS EIL problems
I have started to have random errors with Starting, Putting in gear, SRS Airbag, ABS etc. The car will start up fine but would start acting up in a mile or two. Sometime it wont start but will after removing and reinserting the key. Sometime it wont go into drive or reverse, but pulling the key out and restarting a couple of times, it starts to work. I get the following codes.
ECM
1321 Communication with electronic ignition lock has a malfunction
TCM
U0141 CAN communication with 'CP11 (Electronic ingition lock control unit)' has a malfunction
ESP
631D00 There is a fault in 'EZS'
631E00 There is a fault in 'EZS'
474C00 No CAN message was received from "Motor electronics".
475300 No CAN message was received from 'CP11 (Electronic ignition lock control unit')
475A00 No CAN message was received from 'CP11 (Electronic ignition lock control unit')
63F900 Invalid VIN
SRS
D175 Signal 'Status of circuit 15' was not received
ISM
U016887 Communication with the electronic ignition lock has a malfunction
DSI
U016800 Communication with the electronic ignition lock has a malfunction
Many more communication messages in RMBTMFR, RMBTMFL, MRM, MFK, FSCU, AMGW
Is this a problem with the electronic ignition lock/system. Can the EIS be removed and fixed or do we have to get a new one.
Appreciate the input.
Old Jul 26, 2025 | 03:11 PM
2011 E63 AMG
I found a similar issue of SLK World.
https://www.slkworld.com/threads/eis...oblems.592049/
Could this removing and cleaning the EIS help.
Old Jul 26, 2025 | 05:33 PM
whoover's Avatar
'19 E63S sedan
This is the 213 forum. You might find better help if you post in the W212 AMG forum.
