Brembo Brake Differences
Thanks in advance.
The 09.9313.33 are full-floating rotors. The ring is mounted to the hat using springs, so the ring can expand/move not only vertically, but also horizontally, so it always centers itself between the pads for optimal contact. This improves brake consistency and further improves heat resistance. These also have Brembo's patented Pillar Ventilation Technology for superior internal cooling (https://www.bremboparts.com/america/...erences-204921). These rotors came standard on the 204 C63 Black Series and the GT R when optioned w/o CCB, so these are track ready iron brake rotors. I have them on my C63S Coupe. FTC Euro sells them with lifetime replacement warranty, so you only pay for one set and get full store credit when you return the worn parts. They are excellent rotors. Much more consistent and better at modulating. Worthwhile upgrade and they look the part.
Do a search. We've discussed these a few times.
They’ve gone up though, pre-covid I paid 290.00 ea. 🙁
Good Luck
pre-Covid price
Front AMG 6 piston Brembo Calipers and 2 piece Brembo 390mm Rotor
Good Luck
pre-Covid price
Im looking today and it's 546.79 a piece right now.
I like working on cars and this is my first amg. Intimidates me a little to work on it
@zukmeister I didn't have time for a thorough guide but below are the tutorials I followed. I've never done brakes before but had no trouble using these videos as guides. I was definitely nervous going for that first drive but am happy to report the brakes are working as intended.
Front pad and rotor replacement (this video is for the w212 but the process and all parts used are identical):
https://www.youtube.com/watch?v=mFmmESoqqiY
Rear pad replacement (this video shows a non-AMG car. The only difference is our cars have an AMG cap over the caliper, which means you can't use the caliper spreading tool used in the video. But, I was able to compress the piston using the same type of caliper spreader used on the fronts):
https://www.youtube.com/watch?v=TetxBOPMcCU
Putting the pads in replacement mode(required for rear pads):
https://www.youtube.com/watch?v=hwK5mJLDIf8
Fluid flush (not specific to our cars but I didn't have to deviate from the process described here at all):
https://www.youtube.com/watch?v=JWJIYeourjY
Thank you sir!
https://www.fcpeuro.com/products/mer...211212#fitment
