Clunky shifting after TCU update
Old Sep 7, 2025 | 11:24 PM
SierraFoxtrot's Avatar
E63s AMG
2018 E63
A few months back I had the rear main seal replaced at the dealer. I was told they updated the TCU (Transmission Control Module). I need to confirm what the update was for. Since the update, the shifts are less crisp and clunky on the 2-1 downshift. I don't expect torque converter smooth, but this update seems to be a downgrade. Incidentally, I had a trans service performed at the same time.
Have any of you experienced this? Perhaps I need to put the trans in relearn or maybe flash it back a version.
Old Sep 8, 2025 | 12:03 AM
PeterUbers's Avatar
Originally Posted by SierraFoxtrot
2018 E63
how long had it been between trans fluid changes? How many miles?
how often have you driven the car since the tcu update? It takes a couple hundred miles to adapt; you can also re adapt it with the "pedal dance" procedure and give it another couple
hundred miles.
did you have them re check the trans fluid level? These cars can shift weird if the level is slightly lower than topped off. Dealer did this work - used the correct fluid I presume
also did you add your case to the RMS fail thread?
https://mbworld.org/forums/w213-amg/...fail-club.html
you would need someone like Benzninja to revert the tcu update a dealer applied but it's unclear what's causing your clunking so far
Old Sep 8, 2025 | 12:40 AM
E63s AMG
Thanks for the detailed reply! Almost 60k. Trans fluid changed around 25k and 58k. I've driven it a few thousand since the update.
yes, I am in the RMS db. I am having my oil changed on Tuesday at a new independent shop that specializes in Benz. They have a good rep, so I will ask them to check the fluid level. They may be able to flash the TCU.
Can you detail the "petal dance"?
Old Sep 8, 2025 | 12:45 AM
PeterUbers's Avatar
I made a mistake - for the 9g trans you need xentry to reset the trans adaptations - your Benz tech should be able to do this for you
Old Sep 8, 2025 | 01:17 AM
E63s AMG
Understood. Thank you for the info!
Old Sep 8, 2025 | 01:38 AM
superswiss's Avatar
2019 C63CS
2-1 downshift while still moving? It shouldn't do that in the first place once properly adapted. I have a C63, but same transmission. Mine did the 2-1 downshift initially, until it properly adapted to city driving and hasn't done it since. Now it stays in 2nd until I come to a full stop and then engages 1st while the car is stationary. If I do a California stop, it stays in 2nd. I've also driven a bunch of other AMGs with the 9-MCT since then, including the E63 and none of them downshifted to 1st coming to a stop while still moving, but they were all past the break-in and the transmission was fully adapted. So, if they updated your TCU, yours may have gone back to factory settings, and you need to let it do the whole adaptation cycle again.
