RMS Fail Club
If you had a failed RMS, cut and paste the following and post your pertinent details to add to the database of affected vehicles:
Year: 2019
Model: E63S
RMS Failure Mileage: 38K miles
Style/Frequency of Driving: weekend/spirited
Original Owner: No
Failed Before or After Warranty: After
Has it re-leaked after repair: no
Cost to repair: $5700 (warranty vs OOP)
Who repaired it: Indy vs dealership
For those who are new to the RMS/OVS issue, see this sticky for numerous links of discussions regarding the issue, new part numbers, theories on causes of the failures, posted repair bills, how warranty coverage can help
https://mbworld.org/forums/w213-amg/...fixes-diy.html
Credit to @SM105K for this idea
Model: E63S
Original Owner: No
Has it re-leaked after repair: No
Cost to repair: $0
Who repaired it: Indy dealership fixed it while fixing a upper pan oil gasket under warranty. It was a while they were in there type of thing.
I am the second owner. However, I have spoken to the original owner. He said that he babied the car.
I do not drive it easy. Immediately started modding it after purchase to the mods in my signature.
Model: E63S
RMS Failure Mileage: 36K miles
Style/Frequency of Driving: daily
Original Owner: No
Failed Before or After Warranty: During extended warranty (both times)
Has it re-leaked after repair: yes
Cost to repair: $0 (warranty)
Who repaired it: dealership
They fixed it and replaced the oil separators. Got clunking noise driving it back from the dealer. Took it back for loose exhaust and low coolant. 1 month later it was leaking again. The dealer replaced it again. 6 weeks later it is back in the shop for a CEL (running really rough, low power). Pretty bummed out right now. Thinking of a Avant but the $$$ are pretty high for a new one.
Talking to the uber driver on my way home from dropping it off and told him I love the car, it's my first Mercedes and my last.
Model: S63 Sedan
RMS Failure Mileage: 38.5K miles
Style/Frequency of Driving: Daily
Original Owner: No
Failed Before or After Warranty: During CPO
Has it re-leaked after repair: Repair in progress
Cost to repair: ~ $10,000 (estimated)
Who repaired it: Dealership
Complained of heating trans and oil leak on garage. Took to dealership. They called days later and said rear main seal is leaking.
Model: E63S
RMS Failure Mileage: 47K miles
Style/Frequency of Driving: Spirited/Semi-daily
Original Owner: No
Has it re-leaked after repair: YES, at 52K miles
Cost to repair: $- (Warranty, MB CPO)
Who repaired it: Dealership because of CPO
Model: E63S
RMS Failure Mileage: 67K miles
Original Owner: No/ 2nd onwer
Extended Warranty: Yes, 50% of the cost was covered by my extended warranty purchased from Highline Autos (thanks to Trent)
Here's the link to the thread that goes over my RMS leak experience: https://mbworld.org/forums/w213-amg/...-2019-e63.html
Model: E63S
Model: E63S
RMS Failure Mileage: 50k
Original Owner: No
Cost to repair: $4,618 (separators) - seal completed by uses car lot I bought it from (caught before buying)
Model: S63
RMS Failure Mileage: 60K
Original Owner: Yes.
Failed Before or After Warranty: During extended warranty period.
Has it re-leaked after repair: No.
Cost to repair: unknown - extended warranty covered it.
https://mbworld.org/forums/w213-amg/...y-pricing.html
I installed intakes and a meth injection system
March 2025 I am at 84,000 miles and rear main seal is bone dry, no other leaks whatsoever.
I daily drive it 75 miles back and forth to work and drive it like I stole it.
I change the oil every 5000 miles religiously since I work at the dealership.
I highly recommend against using the Eco feature which has cylinder deactivation. I feel like that does more harm than good to the motor.
I also am not seeing many 2018s coming in to my dealer with this issue, mostly 2019+.
I am the Assistant Service Manager and keep an eye on most AMG issues coming through my department.
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Currently in shop getting RMS done , my mechanic dropped Transmutation and doing it without dropping engine .
also changed oil separators and water thermostat…
he recommended to install oil catch can, is this something anyone has done?
how much did it cost you?
how do you drive the car?
no report of any m177 that I've seen that's installed this AS A RESULT of having ovs and rms issue; nonetheless, catch cans have been often discussed here / read all the rms threads in the sticky:
https://mbworld.org/forums/c63-c63s-...ml#post9039654
Sticky:
Year: 2019
Model: E63S
Original Owner: No
Trenton O. Gibson
Highline Autos
