Mercedes-Benz settled a lawsuit over omitting “high-cost emissions warranty parts”
Manifold PCV Connection Assembly
Power Train Control Unit (PCM)
Accelerator Pedal Sensor
Accelerator Pedal
Partial Load Operation Crankcase Ventilation Valve
Clean Air Line
Pressure Sensor Downstream of Air Filter
Check Valve within the EVAP System
Crankcase Ventilation System
Vent Control Valve
Charcoal Canister
Fuel Tank Level Indicator Fill Level Sensors
Coolant Thermostat
ESP Electronic Stability Program Control Unit
Looks like some RMS failures should be covered.
Still wish they'd recognize the major fault that is the RMS & OVS failure in a hefty percentage of the M177 platform. Alas, this lawsuit looks like it doesn't cover us lowly 2018 MY owners. SAD face 😞
Mike
I don't view this as Mercedes voluntarily deciding to do the right thing. They refused fixing equipment that [California/States that follow California's rules] view as emission related. The agreement is they now have to follow those rules.
Here are my stats:
2018 Wagon
2nd Owner (I purchased in Washington State, but living in Virginia)
47,XXX miles
No issues with leaks (KNOCK ON WOOD!!!)
I believe the lawsuit is covering vehicles within the 4yr/50,000 - 7yr/70,000 age/mileage? Which, if that's the case, then I am not eligible, nor do I think Virginia follows the same emissions standards as California.
Mike
my 2013 had the vacuum pump diaphragm fail which I replaced inexpensively so I’m not really worried about recovering any money but I also just happen to replace my boost pressure converter just as a maintenance item and actually feel that the car is responding a little bit better because it definitely has had oil come through it due to the vacuum pump. and yes, my car is an M157 but because the definition is set, I do believe people will have some good arguments for Goodwill in the future.
kudos to the person that brought the suit
