Will adding bigger rims slow my car down?
The heavier the rim, the slower the wheel can accelerate (and decelerate)
Tire weight makes a difference, too.
I doubt you will be able to tell any difference - the guys who notice have 19" rims, etc.
But, go for wider wheels at rear than front ( amg 5 spoke 7.5 front and 8.5 rear) and you'll love the handling of the car. It will actually feel faster and sportier!!
amazing fun!
go for it!
IMO, there may be an increase in torque required to accelerate the wheel, based on an increase of mass at a given distance from the wheel centre, however this is something that would probably only be measurable on a freewheeling rim. The energy required to move the car would make any such change insignificant on a street car. Are you guys sure you are not confusing a change in overall wheel diameter, which is changing the effective gear ratio?
This site may be of help to you www.differentials.com/faqi.html click under calculator...providing with some tire specs, for comparative purposes you can determine your gains or loss of rpms @ a specific mph.
Regards
Richard
I have never gone to larger wheels and tires without regretting it. Even my daughter wanted 17s on her car and I got them for her birthday but she hates the ride and power loss. Sure they look good but in my book, power rules. You will lose a noticible amount of power. Go to a local track and see what people put on their cars at the track. They swap their cool 18" rims for small 15" wheels with lightweight racing tires.
If current fashion trends dictate a larger rim, then shop for the lightest rim that appeals to you, put on the slimest rubber you can find and swap rear end gears for taller ratio to compensate for the change you made. I laugh when I see people spending $3,000-$5,000 on rims and cheap out on the rear end gears.
I think i will stay with the OEM 16in 7spoke design on my CLK, and replace the Continental tires with S03's.
Now the question is...will adding new tires affect the performance in a negative or positive way?! I know S03's are the best handling and performance tires there are out on the market right now. I mean...Will the tires add weight to my car therefore affecting power?
The stock 16x7" wheel and 205/55/16 wheel combo weighed 36 pounds.
The AMG wheel and 245/40/17 rear combo and the AMG wheel and 225/45/17 combo both weighed 45-46 pounds. Thats 10 to 11 lbs per wheel. And you can feel it.
Plus the suspension or shock has a decreased capacity to control the wheel movement now due to the increased weight.
But the car does corner better, but if I had just put 225/50/16 tires on my stock rims I am sure the car would have handled better also.
Jeff
just put on some 19 inchers and the car will look awsum. And then go and install a kleemans supercharger to compensate for the power loss!
hehe.....
The fact that the entire setup is lighter is an added bonus.
I use 15" drag tires on a street car that I race (I run 17" wheels on the street). The primary reason I went to 15s is that I can get a 27" tall tire with a HUGE sidewall (car is lowered, so I can't run anything larger than 27s). The tall tire also gives me more contact patch.
For the original poster... get a wheel tire combo that has the same overall height as your original and try to keep the weights similiar. An easy formula for calculating tire height =
(width of tire in mm * aspect ratio as decimal)*2/25.4+wheel diameter
So for the rear wheels/tires on my SLK32 -
(245*.40)*2/25.4+17 = 24.72" tall stock rear wheel/tire combo
If I wanted to retain the stock height, I'd get an 18" wheel/tire that was right around that height...
(255*.35)*2/25.4+18 = 25.02" tall - this should be close enough to not throw off the speedo/ABS/TCS/etc.
So, if you're careful with the weight and keep the same overall height, you'll be fine. Enjoy the new wheels/tires
