Why doesn't Tirerack.com...
Old Jul 12, 2005 | 03:38 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
...list if a tire is "directional" or not? Since my car has a staggered wheel set-up, if I want to do my own tire rotations, I need to be able to remove the wheel/tire from one side of the car and place it on the other. I can't do that with directional tires without having them dismounted which is a costly and time consuming excersize. And if the tire is directional AND has a side marked as "outside", I can't rotate it at all. Therefore, for people like me, who will only buy non-directional tires, that specification would be very helpful when shopping on Tirerack.com.
Old Jul 13, 2005 | 04:31 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
it does ... I just looked up a tire at random and read the description
The Bridgestone Potenza RE750 is an Ultra High Performance summer tire that was developed for the drivers of sports cars and sporty coupes to provide traction on wet and dry roads. It uses Bridgestone's UNI-T network of technologies to improve three primary factors of the tire's performance: the bead, casing and tread compound.
The Potenza RE750, inspired by the Bridgestone Potenza racing tire, uses an ultra high performance tread compound to enhance dry traction while its directional tread pattern enhances wet traction. Together, the tread compound and tread design help sweep water away from between the tire's contact patch and the road to improve wet grip (earning the highest "AA" UTQG Traction Rating) and reducing the possibility of hydroplaning. The Potenza RE750 has been engineered to reduce road noise, especially when worn, by combining interconnected shoulder blocks with continuous circumferential ribs in the center of the tread design to help reduce the possibility of heel/toe and alternate block wear. Internally, the Potenza RE750's casing and twin steel belts deliver responsive handling and cornering stability. The steel belts are reinforced with spirally wound nylon to provide high speed durability while minimizing weight and maximizing ride qualities. The Potenza RE750 features Rim Guard rubber ridges on its lower sidewalls to function as bumpers to help protect wheels from curb damage.
Potenza RE750 tires feature subtle black letter styling and will be available in 60-, 55-, 50-, 45-, 40 and 35-series; W-speed rated sizes for 15" to 20" wheel diameters.
Old Jul 14, 2005 | 09:19 AM
So the ad blurb of every single tire describes whether it is directional or not? Since a tire's directionality (is that even a word?) can play a BIG role in poper tire rotation/maintenance, I just wish it was highlighted as part of the tires "specs".
