Tire Pressure question.. re: tire size
Old Sep 13, 2005 | 12:25 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I just upped my CDI from the stock 16" wheels (OEM) to the 17" (OEM) wheels from the E500... the tire went from a 225/55R16 to a 245/45R17...
Do I need to adjust my tire pressure differently? The gas door has a set of numbers, are those still valid?
Also, is there a minus to running slightly higher PSI? I've got 42psi all around..
Old Sep 13, 2005 | 04:43 PM
Jkw's Avatar
Jkw
2004.5 C 230
I would think there would be a difference, my door sticker says 28 front(225/45-17), 32 back (245/40-17).
I believe 5psi over is better than 2psi under, 42 sounds high.
Jkw
Old Sep 13, 2005 | 07:12 PM
CE750's Avatar
Your car is a C? That would explain the different tire pressure... I think the E's are 29PSI.. I'm going to bump them down to 35psi, since I prefer a firmer feel.
Old Sep 14, 2005 | 05:04 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
MB recommended pressures are based on the cars' weight .... stick with what the sticker says
Old Sep 14, 2005 | 05:15 PM
x15jq's Avatar
if your car is lowered with lots of negative camber, will a higher pressure help prevent the inner tire wear by pushing more of the center tread section out?
Old Sep 14, 2005 | 07:24 PM
CE750's Avatar
Thanks, I'll take that to the bank.
Quick follow up.... if the sticker says 29psi, and I run say... 35... will that cause pre-mature wear in the middle of the tire, or is that only if the pressure is way higher? I tend to like how it drives when they're firmer, but don't want to do it at the risk of damage to the tires.
