XPost from S55 forum, re tires
Old Sep 27, 2005 | 09:37 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Replacement Tires for '03 S55. Slim pickings
Time to replace the Bridgestone Potenza RE050 original tires on my '03. These are supposedly the extra load tires.
The '03 OE tires are specified as:
Front: 245/45ZR18 (100Y XL, 800kg/1764# @50psi)
Rear: 265/40ZR18 (101Y XL, 825kg/1819# @ 50psi).
For these exact sizes/specs, I have found the following info:
Bridgestone's own selection guide on its website says that current Potenza RE050 is not available for my car. Hmmm. Seems strange. I can find a spec sheet that shows my tires, but that could be history.
Michelin shows Pilot Sport.
Goodyear has nothing to match the ratings in these sizes.
Pirelli's selector has nothing. (no Y100/Y101 load factor ratings.
Toyo's Proxes don't have the Y100/Y101 Load Factor ratings
TireRack recommends the lower-rated load factor Potenza RE 050 product.
What are you folks using now on your S55 (2003 or later)?
__________________
GrepAwk
Old Sep 28, 2005 | 05:02 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
there is really only 2 choices
Potenza RE050's
Pilot SPorts
Old Sep 28, 2005 | 09:57 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Can you still get the Y100/Y101 rated Potenza RE050's?
I can see your website shows both the Potenza RE050's and the Mich Pilot Sports. But it shows only the Service Descriptions 97Y fr / 96Y for those manufacturers.
The S is a heavy car. And I do want the best.
I am still curious as to why Bridgestone doesn't show the 101Y/101Y ratings available in their online selection guide.
Here's what TireRack's site gave me below:
(Max Performance Summer)
Overview | Specs | Warranty | Reviews | Survey Results | OE Fitments
Sidewall: Blackwall
Front: 245/45YR18 Mercedes Extended (Runflat)
Serv. Desc: 96Y
Price: $272.00
Estimated Availability: In Stock Front:
012345678
Rear: 265/40YR18 Mercedes Extended (Runflat)
Serv. Desc: 97Y
Price: $288.00
Estimated Availability: Low Stock Rear:
012345678
Road Hazard Program $134.40 total with four tire purchase
Michelin Pilot Sport
Overview | Specs | Warranty | Reviews | Test Results | Survey Results
Sidewall: Blackwall
Front: 245/45YR18
Serv. Desc: 96Y
Price: $249.00
012345678
Rear: 265/40YR18
Serv. Desc: 97Y
Price: $306.00
Estimated Availability: In Stock Rear:
012345678
Road Hazard Program $133.20 total with four tire purchase
Old Sep 29, 2005 | 04:45 PM
huh????
RE050
UTQG...................... 140 A A
Service Description....... 100Y
Tire Tread Type........... DIR
Maximum Load.............. 1764 lbs.
Max. Inflation Pressure... 50 psi.
Load Range................ XL
Tread Depth............... 11/32nds.
Rim Protector............. YES
Pilot Sport
UTQG...................... 220 AA A
Tread Depth............... 10/32nds.
remember there are different version of many tires
with that being said MB installs 96 load index tires on that car from the factory in some cases
Old Oct 5, 2005 | 11:39 PM
GrepAwk's Avatar
'03 S55 (79K miles)
A little improvement since last week.
Thanks, Luke.
I would want to get 100Y/101Y service rating, which was O.E. on my car.
Your website selector seems to have been updated since my last post. The proposed RE050 front 245/45YR18 still doesn't have a 100Y service rating. But at least you have added the proposed rear 265/40ZR18 101Y to the pick list since my last post. And I presume I can buy it since it's in stock.
Here's what your site offers now for the 2003 S55:
(Bridgestone RE050)
Front: 245/45YR18
Serv. Desc: 96Y
Price: $219.00
012345678
Rear: 265/40YR18
Serv. Desc: 101Y
Load Rating: XL
Price: $245.00
(RE050 Run Flats..I'm not interested. not 100Y/101Y....)
(Michelin Pilot Sport....still no 100Y or 101Y ratings.)
Front: 245/45YR18
Serv. Desc: 96Y
Price: $249.00
012345678
Rear: 265/40YR18
Serv. Desc: 97Y
Price: $306.00
Old Oct 6, 2005 | 09:56 AM
call me so, I can make sure your get the correct tires
Old Oct 7, 2005 | 09:13 PM
alilock's Avatar
2007 E 63
Tires for S55
I had the same problem with my CL55. After a lot of research, I found that the 255/40/18 PS2's for the front were close enough in diameter to work. The original size of the rear, 265/40/18, obviously work. Could not be happier with them. Much quieter and somewhat more compliant ride.
