Lug nuts??
Old Oct 12, 2005 | 11:52 AM
clk22's Avatar
2003 clk55
Lug nuts??
Car is a 2004 cl500, What size lug nuts or bolts do i need i upgraded to 19x8.5 w/32 off set and 19x9.5 w/35 off set.
Thanks,
Matt
Old Oct 17, 2005 | 10:33 AM
Dvinn's Avatar
03 E500
Thanks,
Matt
It depends on the wheel that you have. Does it take tapered bolts, or ball seat, and how deep does it allow the bolts to intrude out from the wheel?
Usually the best way to figure this out is to call a good dealer that sells lug bolts, or the dealer that sold you the wheels.
Old Oct 27, 2005 | 07:09 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
The C215 CL-Class uses 14mm lug bolts. Dvinn is correct on the seating issue as it'll depend on the wheel as to whether it uses ball seat or acorn. The other thing you may want to do first is test fit the wheel for clearance. On CL's you usually run ET38 or higher. I'm thinking the front wheels are going to stick outside the fender line. The wheels were probably designed to fit C-Class, CLK-Class, or E-Class...
