Rolling rear fenders
Any words of advice before I have this done re: rolling fenders? Should I go to a smaller tire instead (i.e. 265/35s which is 3/10ths of an inch shorter in overall diameter vs. 275/35s) and see if that works first? Any advice is appreciated.
Not a tire expert, but once I removed the Bridgestone Pole Positions S-03's and went to the Goodyear F1's and then later the Dunlops Sport Max, no issues. I also had the car suspension aligned - not by Mercedes, but an alignment specialist.
You might want Mercedes to check the air shocks as well. There was a factory advisory check a while back.
Not sure this helps, but it I have no issues
i would roll the fenders though
I run these same sizes with 20's and my car is lower then yours and it is fine
so w/ 19's and rolled fenders you will love the handling and look better.
ps. I ran this 19 setup I mentioned above before I changed to 20's and it was perfect.
Whatever you do. dont run 265/35s
