Quastion regarding tires size for W211
Old Nov 8, 2005 | 08:33 PM
maximus2004's Avatar
E 320 2003
I have E320 W211
Will i be ok with 18/40/245 in the front tires
18/35/275 in the back or i have to go smaller?
Old Nov 9, 2005 | 02:20 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
go to www.tirerack.com - they indicate the correct sizes. those are good. BTW, tire sizes are written as:
245/40/18
275/35/18
However, if you have dyslexia - I apoligize!
Old Nov 9, 2005 | 03:11 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
W211 Tire Sizing
245/40R18 FA
275/35R18 RA
245/35R19 FA
275/30R19 RA
245/30R20 FA
285/25R20 RA
Staggering on 18's & 19's and all 20's may need fender rolling to prevent rubbing issues.
Old Nov 9, 2005 | 11:21 PM
E 320 2003
so will i be ok with 18" by 8" in the front and 18" by 10" in the back withour rolling fenders or doing any thing?
Old Nov 10, 2005 | 12:02 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
If you run the 10" in the back you will have to roll the rear fenders.
Old Nov 10, 2005 | 01:26 PM
GP03's Avatar
Ken, what does that mean "roll the back fenders"?
Old Nov 10, 2005 | 02:43 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Basically if you put your hand underneath the rear fenders and feel the fender lips, you will notice that a lip portion that is maybe 1/4 to 1/3 inch wide protruding towards the wheel/tire. A fender roll will take this lip and fold it upwards to give you more clearance to avoid rubbing issues when running staggered wheel/tire setups or more aggressive offsets (which push the wheels out more towards the fender line).
It is a common procedure when fitting plus size aftermarket wheels and tires to most cars. AMG cars also have it done at the factory as well as the AMG wheel setups are more aggressive than the stock ones. From an outward appearance you will not be able to notice. You will have to run your hand under the fender to feel whether the lip has been rolled up or not, so it is by no means a drastic measure such as cutting or flaring out fenders.
Usually a shop will have a fender rolling tool. As far as how they work, usually you will put the car on a lift or jack, and remove the wheel. The tool has one end that will bolt up to the axle using the factory lug bolts. It will then consist of an adjustable length arm with a hard rubber roller on the other side. A heat gun is used to warm the fender up (to prevent the paint from being damaged), and then the tool is used in a back and forth motion which rolls the fender lip in a nice even manner.
Old Nov 10, 2005 | 04:19 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
while the W211 E55 uses a 265 in the rear the 275 works fine and is the size I would recommend
Old Nov 11, 2005 | 12:26 AM
E 320 2003
so whats the right maximu spec i can run on my E320 with out doing any fender rolling?
Old Nov 11, 2005 | 12:53 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
If you don't want to do any fender rolling at all on a W211 E320, I'd run an 8.5x18 wheel with a 31 offset on all 4 corners with 245/40R18 all around. If you stagger and do not roll the rear fenders, there is a good chance you will rub in the back.
Old Nov 11, 2005 | 09:43 PM
E 320 2003
well i was kind of looking for something wider in the back i meen tire size something around 255-275 and whats the wides rim for back i can go with no fenders rolling?
Old Nov 14, 2005 | 04:11 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Well, the proper rear stagger tire size to match the front's for your car is 275/35R18. I can't guarantee that a fender roll won't be necessary. Only way to tell for sure is to buy them and fit check. If your car is stock height without the sport package then most likely you will not have to roll the fenders. If the car has the sport package or if you have some heavy people in the back.... it may rub. It will also have alot to do with the wheels you choose and the offsets they are running.
Old Nov 14, 2005 | 10:11 PM
E 320 2003
oh ok so whats the safest offset range u recomend, my car is stock hight no sport pakage
iam thincking of this wheels 18*8 in fron and 18*9 in the back
Old Nov 17, 2005 | 11:19 PM
E 320 2003
up
Old Nov 18, 2005 | 11:20 AM
E55 KEV's Avatar
Veteran: Air Force
this is from the TSW website under inventory:
BREMMA 18x80 5/112 ET32
BREMMA 18x90 5/112 ET35
