any DIY alignment for w203?
Old Feb 8, 2006 | 11:37 AM
pookie's Avatar
2013 c300 4matic, 2002 c240
obviously this is going to be a little difficult. but i know from the old old days in the time of my grandfather (and father) they would do a wheel alignment themselves using rulers, chalk, torque wrench etc. now it is all IR or some other high tech gizmo the helps in the alignment, but the old fashioned way does work still i think.
well, i just got qouted by the dealer for $200 (it was 90$ like a year ago). not many performance shops here in ohio and michigan that are nearby and they probably charge nearly the same. regular mechanics refuse to align my car as welll. i'm just wondering if this can be done.
with the bmw M3, it can be..... http://forum.e46fanatics.com/showpos...31&postcount=6
nothing that came with my w203 was as descriptive.
thoughts................
Old Feb 8, 2006 | 12:09 PM
mig888's Avatar
EVE
If you get a set of rear camber arms and front camber bolts and two laser level-type things that will shoot from your wheel to the wall across from it you could probably do it yourself? (if you know what I mean).
flip
