How are cross-drilled rotors supposed to feel?
Old May 11, 2006 | 02:11 PM
Air Marshall Eldritch's Avatar
John Deere
I have a pair of Performance Products rotors with Porterfield pads. On light braking, they are fine, but with even moderate pressure, they feel and sound like they are rumbling noticeably. Is this normal? It is almost as if the rotors had small bumps instead of holes (they don't, but that's how it feels)
Old May 14, 2006 | 12:07 PM
meanie's Avatar
I have Zimmerman cross-drilled rotors ( front ).
They don't feel any different than the stock rotors.
Did you install yours yourself?
If so, did you clean the hub ( before installing the rotors ) 100 % squeaky clean ?
May want to check the run-out ( wobble ) of the rotor.
Old May 24, 2006 | 05:16 PM
DoubleA's Avatar
2013 E-350 4matic
IF I may ask, where did you get the Zimmerman rotors?
I have been looking around for crossed drilled rotors and no one has the zimmermans in stock. Also what did you pay for them? Thanks. AA..
Old May 24, 2006 | 11:58 PM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
I found Zimmermans for all four corners of the 190 at Drivewire. Don't recall the cost, but it was about the only place I could find that stocked them.
Old May 25, 2006 | 01:03 PM
DoubleA's Avatar
2013 E-350 4matic
where is drive wire ?
Old Jun 2, 2006 | 10:28 PM
DoubleA's Avatar
2013 E-350 4matic
got it thanks
