Kleemann Spring and Koni Shock??Anyone??
Old Sep 4, 2002 | 02:58 AM
HigHal320's Avatar
02 C320, Brilliant Silver
Question Kleemann Spring and Koni Shock??Anyone??
Anyone tried this setup before??
Old Sep 4, 2002 | 10:13 AM
JamE55's Avatar
Out Of Control!
Haven't tried this setup before but if you're planning on going with the Kleemann springs i would highly recommend going with the Kleemann Speed Sensitive Suspensions too. They're really very good on the road!
Old Sep 4, 2002 | 07:23 PM
HigHal320's Avatar
I heard its kind of sporty with speed sensitive shocks so I kind of wants to stay with koni or bilstein.
Old Sep 4, 2002 | 07:30 PM
JamE55's Avatar
Out Of Control!
If that's the case don't think you can go wrong with either Koni or Bilstein setup. Majority of people i've heard is using bilsteins.
Old Sep 4, 2002 | 09:49 PM
Petie's Avatar
2000 CLK430
another difference to consider, konis are adjustable, Bilsteins are not. you can adjust for a smooth or firm ride, while ive heard bilsteins (while i dont have them) are farely stiff. They are both good shocks, its a matter of preference i guess.
Eric
Old Sep 5, 2002 | 12:14 AM
Mach430's Avatar
The Kleemann Speed Sensitive shocks are more comfortable than the Koni's and especially the Bilsteins. Yes, they are sporty when need be, but with multiple variable aperatures you get the best of both worlds. Under normal driving conditions, the ride is smooth and comfortable. Bounce is greatly reduced, but there isn't any harshness. The instant any additional stress is placed upon the shocks, whether by accelerating, turning, or braking, the shocks stiffen up accordingly and provide exceptional performance.
If you opt to go with the Koni's, they are still a great shock. Manually adjustable, as opposed to self-adjusting like the Kleemanns. I have had both on my car, and would recommend either over the Bilsteins.
Ben
Old Sep 5, 2002 | 11:21 AM
nong's Avatar
Go with the Kleemann if you can, they are Beautiful !!!
Old Sep 5, 2002 | 03:48 PM
stephens's Avatar
E55, F550, S600 Ducati 999
HigHal320
Depending on your car, most Koni fitments for MB are not externally adjustable, so while the theory of adjustability is great, you actually have to remove the shock from the car to make the adjustment. If you are prepared to pay for shock to be removed and re-installed like this, you might as well pay for custom valving.
I have heard the Kleemann is great, but it is also very expensive.
Penske or Ohlins shocks are also a great alternative. Both shocks are adjustable for both compression and rebound as well as having "speed sensitive" valving. There are some posts on www.benzsport.com covering fitment of the Penske to a MB
Old Sep 5, 2002 | 07:47 PM
HigHal320's Avatar
Cool
Thanks for all the responds guys =)
I might probably stick with either koni or kleemann.I check both Penske and Ohlins, can't find much for Ohlins but Penske looks sweet the only problem is kind of too pricey (about 2400) but still thanks for responding Stephen.
