Spring Question - which one to get?
Old Sep 9, 2002 | 10:06 PM
shtatc's Avatar
2001 C240 6spd
I know buying springs is like choosing new wheels - there are many to choose from and everyone has their own favorites/opinions. But I would like to know why you chose the spring you installed and how you like it. This will especially help if you only replaced the springs and not the dampers/shocks. I am planning to change the springs only for now - will get the appropriate damper when ready. I really do not want one that will lower the car dramatically - so cup kits are out of the question. Thanks for your feedback.
Old Sep 10, 2002 | 12:39 AM
Tezta's Avatar
CLS350
If you don't want to lower your car much then i think you should go with eibach springs. I had them first on my SLK and they were very comfortable and sat a bit lower than stock with a number 1 spring pad, while impoving the handling. H&R's sit lower and are stiffer than Eibachs. I tried both, and i like the low stance (1.5"drop) so i went with the H&R's.
Old Sep 22, 2002 | 10:41 AM
W0n6_3d4n's Avatar
C200K (w204)
The stiffer the better IMO, softer and lower spring will result in bounceiness (spell??). I had eibach and it can get a bit unssettled
some time, so i think H&R is a good choice.
