Can use of H&R spacers in rear cause vibration?
Old Dec 20, 2006 | 03:19 PM
Carcrazy2's Avatar
03 C230 SS 6spd
I'm getting a slight vibration when using H&R hubcentric 10mm spacers in the rear, but without the spacers no vibration. Can the use of hubcentric spacers in the rear cause a vibration at freeway speeds? Wheel offset is 37 and they are 18x9.
Can the use of spacers accentuate a wheel balance problem?
Thanks.
Old Dec 21, 2006 | 03:10 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
If the rims fit and do not vibrate without them why are you using? Why do you need an offset of et27?
Old Dec 21, 2006 | 08:55 PM
Carcrazy2's Avatar
03 C230 SS 6spd
Just for aesthetics.
Old Dec 21, 2006 | 10:38 PM
rlee02135's Avatar
2004 C32 ///AMG
yes, it will cause the vibration
Old Dec 22, 2006 | 11:37 AM
Carcrazy2's Avatar
03 C230 SS 6spd
what's the reason and how do you know?
Old Dec 22, 2006 | 01:17 PM
Fifth Ring's Avatar
C32 AMG
Vibrations can be the most frustrating problems a car can have. If it vibrates with the spacers and it does not without them, then I think it's safe to blame the spacers!
How? It could be as simple as one of the spacers not seating properly on the hub, or against the tire, making the wheel sit improperly. You might try a second set (loaners) and compare. But it could also be something more fundamental to the suspension caused by a change in offset. Any of the many links and joints can start to vibrate oddly, and oscillate because of the unusual force caused by the new offset. Audi has just such an issue with the older S6. People go through new tires, new wheels, new control arms, and sometimes it goes away, and sometimes not.
Old Dec 27, 2006 | 07:50 PM
Carcrazy2's Avatar
03 C230 SS 6spd
Hey thanks for the insight. Initially I too thought that it was the change in offset magnifying something loose in the suspension, until I looked more closely at the fitment of the spacers.
It turns out the that even highly acclaimed H&R spacers can have a fitment issue! The hub extension that the wheels fit on are smaller in diameter than they should be by 1 mm and that makes the wheels non-hubcentric! I'll be getting H&R to replace them.
