will these wheels / tires fit on my W209 CLK 320
Old Jan 11, 2007 | 07:08 PM
Go Terps's Avatar
I'm looking to get new wheels / times for my CLK 320.
I've come across this set but I'm not sure they will fit - without doing any customizations.
The wheels are 18 x 8.5 5-112 all around. Offset is 44mm.
The tires are 245/45R18 all around.
I appreciate any feedback.
Also, can someone explain - in simple english - what offset is?
Old Jan 11, 2007 | 08:53 PM
chixdiggit's Avatar
W209 CLK
I copied and pasted it from the Tirerack FAQ. That is the new person's bible to wheel information
Offset:
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
Old Jan 24, 2007 | 07:33 PM
Go Terps's Avatar
So can anyone tell me if these wheels will fit my CLK 320 or not?
Old Jan 25, 2007 | 12:45 PM
CLS55Lucas's Avatar
CLK should have staggered wheels, wider in back. I would keep with the OE sizes myself.
Are you sure the bolt pattern is the same on the new ones?
